.ZIP file for custom widgets
3168
09-04-2013 08:22 AM
TAMARADIEZ
I am just starting to use the ArcGIS Viewer for Flex. Can someone please tell me from where I can download the .ZIP files for the custom widgets.
Many thanks,
T
RobertScheitlin__GISP
Tamara,
   You do a search on ArcGIS.com for flex Widgets (not all widgets have a zip that is ready for Application Builder).
Here is a search for all my flex widgets:
http://www.arcgis.com/home/search.html?q=flex%20widgets%20and%20owner%3Arscheitlin&t=content&start=1
TAMARADIEZ
Tamara,
Many thaks for your reply. If the widget doesn't have a .ZIP file ready but I find the code. Do I need Flex of something else to create the .ZIP?
Could you please explain to me the general steps/
Kind Regards,
T
TAMARA,
   If the widget does not have a zip then it is not designed by the developer to be compatible with application builder or is not supported by application builder (as layout widgets are not currently supported). There is nothing on your end to do, it is just not supported.
