WMS doesn't overlay correctly (4326)
2253
10-29-2012 05:44 PM
WillHughes1
My operational layer (wms wkid=4326) doesn't overlay correctly with the basemap below which is also in WGS84 (wkid=4326). See attached screenshot.
<map wraparound180="true" initialextent="126.987 37.066 127.060 37.098" fullextent="-179 -89 179 89" top="40">
Basemap:
<basemaps>
<layer label="Streets" type="tiled" visible="true"
url="http://server.arcgisonline.com/ArcGIS/rest/services/ESRI_Imagery_World_2D/MapServer"/>
</basemaps>
operational layer is:
<layer label="Weather" type="wms" visible="true" visiblelayers="LAND,BOUNDARIES,Present_Wx" FORMAT="image/png" alpha="0.8" styles="default"
url="https://somedomain.com/services/WMS?CRS=EPSG:4326" skipgetcapabilities="true" version="1.3.0" />
Any ideas? I am using the 3.0 FV.
Thanks.
Will
DasaPaddock
Can you try with: version="1.1.1"
DasaPaddock
Try changing the URL to: https://somedomain.com/services/WMS
and remove the version="1.3.0"
WillHughes1
Same result after removing the version and changing the URL.
-Will
DasaPaddock
WillHughes1
Well how about that. It works now that I changed the version to 1.1.1.
Thanks.
It is intersting however that I cannot see the wms in the FV until after I open the wms URL in my browser, which prompts me for my certificate. Is there a way for the FV to prompt for secured services which require a certificate?
Will
DasaPaddock
