Widgets - Undefined state 'open'. ERROR
4677
13
09-01-2010 04:24 AM
Kevin_RogersBwire
Flex Team,
I am getting a problem whenever I insert a widget e.g the searchwidget into my custom adobe flex web map applications. After runnning itm I get the following error
ArgumentError: Undefined state 'open'.
at mx.core::UIComponent/getState()
at mx.core::UIComponent/findCommonBaseState()
at mx.core::UIComponent/commitCurrentState()
at mx.core::UIComponent/commitProperties()
at spark.components.supportClasses::GroupBase/commitProperties()
at spark.components::Group/commitProperties()
at mx.core::UIComponent/validateProperties()
at mx.managers::LayoutManager/validateProperties()
at mx.managers::LayoutManager/doPhasedInstantiation()
at mx.managers::LayoutManager/doPhasedInstantiationCallback()
What is the cause?
RobertScheitlin__GISP
Kevin,
     When you say
do you mean that it is not the sample flex viewer 1.x or the FlexViewer2.0? If so than you have a real issue as the search widget is dependent on the viewers framework and you can not just add it to a custom flex app. There are a couple of non SFV versions of widgets out there here is a link to the non-SFV searchWidget.
http://www.arcgis.com/home/item.html?id=2d2ccae108b74b1ba8968e21c730bdb4
Ganael_Jatteau
After upgrading the Esri flexviewer from 2.0 beta to 2.1, I have the same issue. When a widget gets loaded, I get the same error: Widgets - Undefined state 'open'. ERROR
Debugging the application, I found that widget templates have two states: disabled and normal
I'm investigating... Maybe a compiler argument to add...
Ganael
Ganael,
   Hmm.... the 2.1 Version WidgetTemplate has
[SkinState("open")]
[SkinState("minimized")]
[SkinState("closed")]
Are you missing this?
yangyi
�?位�?�??�?碰�?��?个�?��?�?不�?��?�?个�?��?�??没�??解�?��?
Snyod,
   確保你�??�??�?�??家�?��?��??Widget模板
[SkinState("open")]
yangyi
Snyod,
[SkinState("open")]
�?常�??谢rscheitlin
�?�WidgetTemplate.as�??件�??�??�?�?�?
[Event(name="open", type="flash.events.Event")]
[Event(name="minimized", type="flash.events.Event")]
[Event(name="closed", type="flash.events.Event")]
[SkinState("open")]
public class WidgetTemplate extends SkinnableContainer implements IWidgetTemplate
�?�使�?��??�?��?�??已編譯�??�?件�?�??�??�?��??�?�?��?
你�?�?�?�??�??乾淨�??�?�?�?��?�?��??�?
yangyi
�??�??�?��?��?个index.mxml �?� src �?��?�?
�?��?�?��?�建�?个index.mxml�?? �?�运�?�?序就�?ArgumentError: Undefined state 'open'.
Yang,
尝�?�?��?��??bin- debug�??件夹中�??�??容�??�?��?�?项�?��?�?�?�??�?�?�?�令�??
Try deleting the contents of the bin-debug folder. Then run the clean command from the project menu.
