WidgetManager Error #2124
14811
35
01-09-2012 07:23 AM
JustinGleeson
I have deployed a ThematicQueryWidget in my application. This works well but I always get a WidgetManager Error #2124 when I open the mapping viewer (see attached). This does not seems to stop the widget from working though. Any idea what causes this?
Code in main config
<widget label="Accessibility Maps" width="300" height="500"
                preload="open"
                left="95" top="50"
                icon="AccessMap_WidgetsPopUpsETC/assets/AccessMapTMW.png"
                config="AccessMap_WidgetsPopUpsETC/ThematicQueryWidgetAccessMap.xml"
                url="AccessMap_WidgetsPopUpsETC/widgets/Thematic Query Widget/ThematicQueryWidget.swf"/>
Code in ThematicQueryWidgetAccessMap.xml
<?xml version="1.0" ?>
<configuration>
    <!-- labelref should match the label of the operational layer's label in main config. -->
    <theme labelref="Train Stations" >
<query legendurl="AccessMap_WidgetsPopUpsETC/assets/AccessMap_National.png" >
       </query>
    </theme>
</configuration>
thanks
Justin
RobertScheitlin__GISP
Justin,
    Glad you got it worked out. Please mark this post as answered by click on the check under this image: and promote by clicking on the upper arrow on any posts that helped you.
Justin,
   Flex error 2124 means "Loaded file is an unknown type". The fact that you are getting this from the widget manager would lead me to closely look at your main config.xml and check spelling and/or syntax errors.
JustinGleeson
Justin,
I've just noticed that the sample I was following as an example (US Thematic Map) has the Unemployment and Population Density set up as "tiled" whereas my layers are "dynamic". Do you think this has anything to do with it?
thanks
Justin,
   It will probably be easier if you post you main config.xml for me to look at.
JustinGleeson
Justin,
Robert,
OK. Main config is below. It's strange as everything works perfectly apart from the error window popping up once the application is opened.
Many thanks
<configuration>
    <title>AIRO-ICLRD Accessibility Map</title>
    <subtitle>Promoting best practice in spatial planning</subtitle>
    <logo>AccessMap_WidgetsPopUpsETC/assets/i_iclrd.png</logo>
    <style>
        <colors>0xFFFFFF,0x333333,0x101010,0x000000,0xFFD700</colors>
        <alpha>1.0</alpha>
    </style>
    <!-- replace the following url with your own geometryservice -->
    <geometryservice url="http://tasks.arcgisonline.com/ArcGIS/rest/services/Geometry/GeometryServer" />
<splashpage label="AIRO-ICLRD Accessibility Map" config="AccessMap_WidgetsPopUpsETC/widgets/Splash/SplashWidget_AccessMap.xml" url="AccessMap_WidgetsPopUpsETC/widgets/Splash/SplashWidget.swf"/>
    <!-- User Interface elements -->
    <widget left="10"  top="50"    config="widgets/Navigation/NavigationWidget.xml" url="widgets/Navigation/NavigationWidget.swf"/>
<widget right="20" top="85"  url="widgets/StaticImage/StaticImageWidget.swf"/>
    <widget right="-2" bottom="-2" config="widgets/OverviewMap/OverviewMapWidget.xml" url="widgets/OverviewMap/OverviewMapWidget.swf"/>
    <widget right="20" top="55"    config="widgets/MapSwitcher/MapSwitcherWidget_Thematic.xml" url="widgets/MapSwitcher/MapSwitcherWidget.swf"/>
<widget left="0"   top="0"     config="widgets/HeaderController/HeaderControllerWidget.xml" url="widgets/HeaderController/HeaderControllerWidget.swf"/>
    <map wraparound180="true" initialextent="-1783000 6801000 -223000 7370000" fullextent="-20000000 -20000000 20000000 20000000" top="40">
        <basemaps>
      <layer label="OpenStreetMap" type="osm" visible="true" />
                  <layer label="Aerial" type="tiled" visible="false" url="http://server.arcgisonline.com/ArcGIS/rest/services/World_Imagery/MapServer" />
        </basemaps>
  <!--<map initialextent="697155.0534 718823.4116 715563.1148 736155.2542"top="40">
        <basemaps>
            <layer label="Streets" type="tiled" visible="true"alpha="1"
       url="https://webservices.osi.ie/WebServ/rest/services/WebServices/Orthos2005_ITM/MapServer"/>
            <layer label="Aerial"  type="tiled" visible="false"alpha="1"
       url="https://webservices.osi.ie/WebServ/rest/services/WebServices/New_Ireland_ITM/MapServer"/>
        </basemaps>  -->
        <operationallayers>
  <layer label="Gateways" type="dynamic" visible="true" alpha="0.65"
         url="http://na-lap-347/ArcGIS/rest/services/Gateways/MapServer">
   <sublayer id="0" popupconfig="AccessMap_WidgetsPopUpsETC\popups\PopUp_Gateways.xml"/>
   </layer>
  <layer label="Gateways and Hubs" type="dynamic" visible="false" alpha="0.65"
         url="http://na-lap-347/ArcGIS/rest/services/GatewaysHubs/MapServer">
   </layer>
  <layer label="Settlements > 50,000" type="dynamic" visible="false" alpha="0.65"
         url="http://na-lap-347/ArcGIS/rest/services/Towns50000/MapServer">
   </layer>
  <layer label="Settlements > 20,000" type="dynamic" visible="false" alpha="0.65"
         url="http://na-lap-347/ArcGIS/rest/services/Towns20000/MapServer">
   </layer>
  <layer label="Settlements > 10,000" type="dynamic" visible="false" alpha="0.65"
         url="http://na-lap-347/ArcGIS/rest/services/Towns10000/MapServer">
   </layer>
  <layer label="Settlements > 5,000" type="dynamic" visible="false" alpha="0.65"
         url="http://na-lap-347/ArcGIS/rest/services/Towns5000/MapServer">
   </layer>
  <layer label="Settlements > 1,500" type="dynamic" visible="false" alpha="0.65"
         url="http://na-lap-347/ArcGIS/rest/services/Towns1500/MapServer">
   </layer>
  <layer label="Primary Schools" type="dynamic" visible="false" alpha="0.65"
         url="http://na-lap-347/ArcGIS/rest/services/PrimarySchools/MapServer">
   </layer>
  <layer label="Secondary Schools" type="dynamic" visible="false" alpha="0.65"
         url="http://na-lap-347/ArcGIS/rest/services/SecondarySchools/MapServer">
   </layer>
  <layer label="Main Internationl Airports" type="dynamic" visible="false" alpha="0.65"
         url="http://na-lap-347/ArcGIS/rest/services/AirportsInt/MapServer">
   </layer>
  <layer label="Main Airports" type="dynamic" visible="false" alpha="0.65"
         url="http://na-lap-347/ArcGIS/rest/services/AirportsAll/MapServer">
   </layer>
  <layer label="Train Stations" type="dynamic" visible="false" alpha="0.65"
         url="http://na-lap-347/ArcGIS/rest/services/TrainStations/MapServer">
   </layer>
  <layer label="Full Emergency Hospital (24hr)" type="dynamic" visible="false" alpha="0.65"
         url="http://na-lap-347/ArcGIS/rest/services/Hospital24Emergency/MapServer">
   </layer>
  <layer label="Partial Emergency Hospital" type="dynamic" visible="false" alpha="0.65"
         url="http://na-lap-347/ArcGIS/rest/services/Hospital_AllEmergency/MapServer">
   </layer>
  <layer label="GP Surgery" type="dynamic" visible="false" alpha="0.65"
         url="http://na-lap-347/ArcGIS/rest/services/GPs/MapServer">
   </layer>
  <layer label="Dentists" type="dynamic" visible="false" alpha="0.65"
         url="http://na-lap-347/ArcGIS/rest/services/Dentists/MapServer">
   </layer>
  <layer label="Pharmacies" type="dynamic" visible="false" alpha="0.65"
         url="http://na-lap-347/ArcGIS/rest/services/Pharmacy/MapServer">
   </layer>
  <layer label="Fire Stations" type="dynamic" visible="false" alpha="0.65"
         url="http://na-lap-347/ArcGIS/rest/services/FireStations/MapServer">
   </layer>
  <layer label="Garda or PSNI Stations" type="dynamic" visible="false" alpha="0.65"
         url="http://na-lap-347/ArcGIS/rest/services/PSNIGarda/MapServer">
   </layer>
  <layer label="RoI Counties" type="dynamic" visible="true" alpha="0.65"
         url="http://na-lap-347/ArcGIS/rest/services/RoICounties/MapServer">
   </layer>
        <layer label="NI Districts" type="dynamic" visible="true" alpha="0.65"
         url="http://na-lap-347/ArcGIS/rest/services/NIDistricts/MapServer">
   </layer>
        </operationallayers>
    </map>
    <!-- widgets organized into widget containers that manage close/open etc -->
    <!-- supported layout property options: horizontal(default)|float|vertical|fix-->
    <widgetcontainer layout="float">
<widget label="Accessibility Maps" width="330" height="500"
                preload="open"
                left="95" top="50"
                url="AccessMap_WidgetsPopUpsETC/widgets/ThematicQueryWidget/ThematicQueryWidget.swf"/>
    <widget label="Bookmarks"         left="430" top="90"
                icon="assets/images/i_bookmark.png"
                config="widgets/Bookmark/BookmarkWidget.xml"
                url="widgets/Bookmark/BookmarkWidget.swf"/>
    <widget label="Print" left="390" top="400"
                icon="assets/images/i_print.png"
                config="widgets/Print/PrintWidget.xml"
                url="widgets/Print/PrintWidget.swf"/>
    </widgetcontainer>
</configuration>
Justin,
  Try this cleaned and formatted version of your XML and see if it produces any different results (ensure you clear your browsers cache).
<configuration>
    <style>
        <alpha>1.0</alpha>
    </style>
    <geometryservice
        url="AccessMap_WidgetsPopUpsETC/widgets/Splash/SplashWidget.swf" />
        url="widgets/Navigation/NavigationWidget.swf" />
    <widget right="20" top="85" url="widgets/StaticImage/StaticImageWidget.swf" />
        url="widgets/OverviewMap/OverviewMapWidget.swf" />
        url="widgets/MapSwitcher/MapSwitcherWidget.swf" />
        url="widgets/HeaderController/HeaderControllerWidget.swf" />
        <basemaps>
        </basemaps>
            <basemaps> <layer label="Streets" type="tiled" visible="true"alpha="1" url="https://webservices.osi.ie/WebServ/rest/services/WebServices/Orthos2005_ITM/MapServer"/>
            <layer label="Aerial" type="tiled" visible="false"alpha="1" url="https://webservices.osi.ie/WebServ/rest/services/WebServices/New_Ireland_ITM/MapServer"/>
            </basemaps> -->
        <operationallayers>
                <sublayer id="0" popupconfig="AccessMap_WidgetsPopUpsETC\popups\PopUp_Gateways.xml" />
            </layer>
            </layer>
            <layer label="Settlements &gt; 50,000" type="dynamic" visible="false"
                alpha="0.65" url="http://na-lap-347/ArcGIS/rest/services/Towns50000/MapServer">
            </layer>
            <layer label="Settlements &gt; 20,000" type="dynamic" visible="false"
                alpha="0.65" url="http://na-lap-347/ArcGIS/rest/services/Towns20000/MapServer">
            </layer>
            <layer label="Settlements &gt; 10,000" type="dynamic" visible="false"
                alpha="0.65" url="http://na-lap-347/ArcGIS/rest/services/Towns10000/MapServer">
            </layer>
            <layer label="Settlements &gt; 5,000" type="dynamic" visible="false"
                alpha="0.65" url="http://na-lap-347/ArcGIS/rest/services/Towns5000/MapServer">
            </layer>
            <layer label="Settlements &gt; 1,500" type="dynamic" visible="false"
                alpha="0.65" url="http://na-lap-347/ArcGIS/rest/services/Towns1500/MapServer">
            </layer>
            </layer>
            </layer>
            </layer>
            </layer>
            </layer>
            </layer>
            </layer>
            </layer>
            </layer>
            </layer>
            </layer>
            </layer>
            </layer>
            </layer>
    </map>
    <!-- supported layout property options: horizontal(default)|float|vertical|fix -->
            preload="open" left="95" top="50"
            url="AccessMap_WidgetsPopUpsETC/widgets/ThematicQueryWidget/ThematicQueryWidget.swf" />
            url="widgets/Bookmark/BookmarkWidget.swf" />
            url="widgets/Print/PrintWidget.swf" />
    </widgetcontainer>
</configuration>
JustinGleeson
Hi Robert,
thanks for taking the time to look at this. No change through I'm afraid. The same error is coming up
Justin
Justin,
   If you comment out the themeatic widget does the error go away?
JustinGleeson
Justin,
Yes, no error. Once the following is operational the error appears
Justin,
   Have you double checked the paths then? Is this the right path and is there actually a AccessMapTMW.png in that folder?
What about the swf did you add the ThematicQueryWidget to your projects modules list and is it in that exact folder?
