Widget Search Error
3276
8
05-13-2013 07:24 PM
YanuardiHerdiyono
Dear All,
I got message like this "[RPC Fault faultString="Invalid or missing input parameters." faultCode="400" faultDetail=""]" when used search widget. Now I'm using flex viewer 3.1 and the data from joint table. When I remove the joint table, its work. So how to use search widget from joint table data? Thanks before..
-yanuardi
RobertScheitlin__GISP
yanuardi,
   When you do a Search on a joined layer you need to use the full name of the joined field in your fields list and/or expression (i.e. dbo.main.field1)
Don't forget to click the Mark as answer check on this post and to click the top arrow (promote).
Follow these steps as shown in the below graphic:
yanuardi,
yanuardi,
  You missed the most important step so let me tryout my new step by step graphic:
YanuardiHerdiyono
Dear rscheitlin,
I have done with this:
<configuration>
    <zoomscale>50000</zoomscale>
    <shareresults>false</shareresults>
    <layers>
        <layer>
            <name>Nama Sumur</name>
            <url>http://myserver:6080/arcgis/rest/services/PureGDB/MapServer/1</url>
            <expression>upper(geodatabase.DBO.sp_well.well_name) like upper('%[value]%')</expression>
            <textsearchlabel>Isi Nama Sumur</textsearchlabel>
            <titlefield>geodatabase.DBO.sp_well.well_name</titlefield>
            <fields>
                <field name="geodatabase.DBO.sp_well.well_name" alias="Well Name"/>
                <field name="geodatabase.DBO.sp_well.well_status_id" alias="Well Status"/>
            </fields>
            <orderbyfields>geodatabase.DBO.sp_well.well_name</orderbyfields>
        </layer>
    </layers>
</configuration>
Its true?
yanuardi,
Yanuardi,
   I have never seen anything in front of DBO before so you should check your field names again. The best way to do this is type http://myserver:6080/arcgis/rest/services/PureGDB/MapServer/1 in the address bar of your browser and this will take you to the REST Service directory page for that service, scroll down to the fields listing and you will see the fields listed like this:
Fields:
  • Parcels3.OBJECTID ( type: esriFieldTypeOID , alias: OBJECTID )
  • Parcels3.TMP_NO ( type: esriFieldTypeString , alias: Temp Number , length: 23 )
  • Parcels3.MIN_CALC_ACRES ( type: esriFieldTypeDouble , alias: Minimum Calculated Area )
  • Parcels3.PPIN ( type: esriFieldTypeString , alias: PPIN , length: 6 )
  • Parcels3.PARCEL_NUMBER ( type: esriFieldTypeString , alias: Parcel Number , length: 29 )
  • Parcels3.OLD_NEW_FLAG ( type: esriFieldTypeString , alias: Old or New Flag , length: 1 )
  • Parcels3.NAME ( type: esriFieldTypeString , alias: Name , length: 40 )
  • Parcels3.ADDRESS_1 ( type: esriFieldTypeString , alias: Address Line 1 , length: 30 )
  • Parcels3.ADDRESS_2 ( type: esriFieldTypeString , alias: Address Line 2 , length: 30 )
  • Parcels3.ADDRESS_3 ( type: esriFieldTypeString , alias: Address Line 3 , length: 30 )
Those are the field names you would want to use.
YanuardiHerdiyono
Dear Robert,
My data like this:
Fields:
    geodatabase.DBO.sp_well.OBJECTID ( type: esriFieldTypeOID , alias: OBJECTID )
    geodatabase.DBO.sp_well.well_id ( type: esriFieldTypeSmallInteger , alias: Well ID )
    geodatabase.DBO.sp_well.well_name ( type: esriFieldTypeString , alias: Well Name , length: 50 )
    geodatabase.DBO.sp_well.cluster_id ( type: esriFieldTypeSmallInteger , alias: Cluster ID )
    geodatabase.DBO.sp_well.field_id ( type: esriFieldTypeSmallInteger , alias: Field ID )
    geodatabase.DBO.sp_well.well_status_id ( type: esriFieldTypeSmallInteger , alias: Well Status )
    geodatabase.DBO.sp_well.SHAPE ( type: esriFieldTypeGeometry , alias: SHAPE )
    PURe.dbo.well_info.well_character ( type: esriFieldTypeString , alias: Well Character , length: 50 )
    PURe.dbo.well_info.rig_name ( type: esriFieldTypeString , alias: Rig Name , length: 50 )
    PURe.dbo.well_info.final_td ( type: esriFieldTypeDouble , alias: Final TD )
    PURe.dbo.well_info.max_tvd ( type: esriFieldTypeDouble , alias: Maximum TVD )
    PURe.dbo.well_info.start_easting ( type: esriFieldTypeDouble , alias: Start Easting )
    PURe.dbo.well_info.start_northing ( type: esriFieldTypeDouble , alias: Start Northing )
    PURe.dbo.well_info.end_easting ( type: esriFieldTypeDouble , alias: End Easting )
    PURe.dbo.well_info.end_northing ( type: esriFieldTypeDouble , alias: End Northing )
    PURe.dbo.well_info.coordinate_system ( type: esriFieldTypeString , alias: Coordinate System , length: 80 )
Yanuardi,
   Well it looks like what you posted in in your earlier thread should work then.
YanuardiHerdiyono
Yanuardi,
<textsearchlabel>Search Intersection  [ Example: 2ndst and 4th st ]:</textsearchlabel>
Robert,
I still got error message "[RPC Fault faultString="Invalid or missing input parameters." faultCode="400" faultDetail=""]"..
Yanuardi,
   I would go to the REST Service Diresctory page (as I instructed before) and test your query by clicking the query link at the bottom of the page and filling in the web form with the fields and SQL expression. Maybe doing it from the web form will shead some light on what is going wrong.
