White screen from clicking widget
983
04-11-2012 09:41 AM
LaurenMasse
I recently acquired some widgets from another department and I've saved them into the appropriate folders within widgets. Opening my Flex Viewer, no errors come up which leads me to believe nothing's wrong with the config file. However, when I click on the widget icon, the Flex Viewer screen goes white. No error, no pop-up, it's not even a different window, the URL says it's still on the Flex Viewer page. Any ideas of how to fix this and what's causing the issue?
EricGardecki
You said you loaded multiple widgets...does this only happen on one or all?
If it's just the one it doesn't seem like it's anything cfg related.  Must be an issue with that particular widget.
Are you using the same version of the flexviewer as your source of the widgets?
