where is .as compiled code?
2920
11
05-03-2011 04:04 AM
AshleyOwens
I have made changes to \src\com\esri\viewer\components\toc\tocClasses\*.as and would like to deploy these to another environment. I'm assuming an "Export Release Build" should be done, but where is the compiled code located? What needs to be migrated to the next environment?
AshleyOwens
I found the solution. I guess for caching reasons, I also had to update MapSwitcherWidget.swf, even though there were no code changes made to this widget.
RobertScheitlin__GISP
Ashley,
  Actually that make a lot of sense as the MapSwitcherWidget.mxml uses the toc classes.
