Problem with Programatically Updating TOC visibility
2000
05-03-2011 09:22 AM
JamesFaron
I am basically following steps from this forum topic:http://forums.arcgis.com/threads/20965-LiveMapsWidget-doesn-t-follow-changes
I changed TocItem.as (in both Robert's TOC Widget directory, and in src\components\tocClasses) as follows:
public class TocItem extends EventDispatcher
    public function TocItem(parentItem:TocItem = null)
        _parent = parentItem;
  ViewerContainer.addEventListener(AppEvent.PROGRAMATIC_LAYER_VISIBILITY_CHANGED, updateCheckBox);
 private function updateCheckBox(event:AppEvent):void
  if(this is TocLayerInfoItem)
   var tli:TocLayerInfoItem = this as TocLayerInfoItem;
   if(tli.layerInfo.name == event.data){
    //setVisibleDirect(true);
    setVisible(_visible ? false : true, true)
Entered Public static const in AppEvent.as:
public static const PROGRAMATIC_LAYER_VISIBILITY_CHANGED:String = "programicLayerVisibilityChanged";
Finally, called it in a widget as follows:
private function test1(evt:Event):void
     ViewerContainer.dispatchEvent(new AppEvent(AppEvent.PROGRAMATIC_LAYER_VISIBILITY_CHANGED, "Students"));
The end result is that the TOC layer is not updated from visible=false to visible=true. I must be missing a step, or perhaps something changed in a version update?
Jim Faron
Austin Independent School District
