View Relationship Classes in Pop up window?
1828
5
06-07-2012 05:39 AM
JustinNettleton
I am working on a map for our Parks and Rec Department. I am wanting to show reservation detail for a camp site when they click on that particular site. I have the reservation data in a relationship class as a one to many to the parcel data. Is there any way to configure the pop-up to show that relationship class data?
RobertScheitlin__GISP
Justin,
   No my identify widget does not support relates either. The only thing that is close is my Attachment Relate Info Window Widget.
http://www.arcgis.com/home/item.html?id=4ec33120c9ea4d019fddf722fc34ea3c
Justin,
   Not without some pretty extensive custom development in the PopUpRendererSkin.mxml.
Don't forget to click the Mark as answer check on this post and to click the top arrow (promote).
Follow the steps as shown in the below graphic:
JustinNettleton
Ok, thanks for the info. What about the Identify widget? Anything you can do with that to make it pop up?  I am assuming no, but thought I would ask.
Justin,
JustinNettleton
This is going to work perfect I think.
Thanks very much.
FaizanTayyab
I know that related table data cannot be displayed in Flex pre3.0 but has it changed in new version of 3.0. It seems to be a big limitation not being able to show 1:M relationships. I have got a workaround that uses two queries but would like to know if the query can contain joins.
