Using pop-up windows with time aware layers for identify
926
05-25-2011 11:30 PM
KristelMeikas
Hello,
I have an application with several time aware layers for which I need to enable identify functionality. Has anyone else tried using pop-up windows with TimeWidget and got the correct behaviour - by correct I mean that identifiable features depend on the time "selected" in the TimeWidget?
Currently I always seem to get a pop-up for the earliest data for a feature (features in the layer cover the whole subject area as a grid of polygons based on measurement data received at specified intervals). I'm guessing that (if there isn't a solution built in which I haven't found) I should dynamically add a definition expression to the identify task at runtime based on the time selected in TimeWidget? But what about when TimeWidget is closed - how do I determine which hour to show results for? Or is there another better solution to this issue?
Thanks in advance,
Kristel
NicoleSulzberger
Hi Kristel
Have you resolved your problem, and if yes, what was the problem? It looks like I have the same problem in my application. I set the first date of the time parameter to a certain date, but the feature I get back was valid much earlier, and not valid at this date. I am calling the Identify Task programmatically, and I am not using the time slider. Some of my layers are time-aware, others aren't.
bye, Nicole
KristelMeikas
Hi Nicole,
I didn't actually find out what the problem was, but the way I solved it was by using Robert Scheitlin's Identify Widget with small additions to the identifyFeatures method in IdentifyWidget.mxml:
if (map.timeExtent != null)
 identifyParams.timeExtent = new TimeExtent(map.timeExtent.endTime, map.timeExtent.endTime);
In our case I only needed to show data from the exact instant chosen on the time slider, not a time span, that's why I used only the time slider end time for creating a new time extent for the identify parameters.
You might also want to play a bit with timezones in the map document and service, because for a while we had an issue with UTC and local timezone differences - unfortunately, I don't have the map service anymore to check how exactly we got over that.
Hope that helps,
Kristel
NicoleSulzberger
Hi Kristel
Thank you very much for your response. We are only using a tim3 and not a time extent, so we'll try to set both times of the extent instead of just one, maybe that will help.
bye, Nicole
