Unknown GraphicsLayer in Legend Widget Display?
1388
10-03-2013 11:50 AM
GeorgeHaskett
I am using ArcGIS 10.1 and Viewr for Flex 3.4.
For some reason when I open my legend widget, I consistently see two unknown graphic layers.  The numbers have changed at least once, but typically it looks as follows:
GraphicsLayer265
GraphicsLayer266
[ATTACH=CONFIG]28024[/ATTACH]
The only thing different from this map and some of my other maps is that I am using the Edit widget.
Anyone know where this is coming from and how to remove them?
Haskett
GISDev1
GraphicsLayer265
GraphicsLayer266
Haskett
I think you are seeing this bug:
https://github.com/Esri/arcgis-viewer-flex/issues/159
Which was fixed for V3.5.
If you can't update to 3.5 for some reason, and if you are comfortable editing the source code, just open the LegendWidget.mxml and change the code as it was changed on GitHub for 3.5.
GISDev1
GraphicsLayer265
GraphicsLayer266
Haskett
GeorgeHaskett
Awesome, thanks for the heads up.
I will hopefully be upgrading to 3.5 later this week when I finish a project I am currently working on.  I'll post back if the upgrade resolves my issues.
Haskett
