Unable to apply edits
1930
01-08-2013 10:04 AM
NicholasEntinger
I am running ArcServer 10.1 and Flex Viewer 3.0. I am attempting to edit a feature class in a 9.3.1 SDE geodatabase using the Edit widget. The feature class has been registered as versioned and I am able to edit the feature class from ArcMap.
When I click a feature I am able to change the geometry or an attribute value, however when I click OK the edit doesn't show up and the apply edits function throws out this error message:
{"error":{"code":400,"message":"Unable to complete operation.","details":[]}}
Does anyone know what might be going on? Can applications built in flex viewer be used to edit 9.3 SDE geodatabases?
Nick Entinger
Information Systems Specialist
MN.IT Services @ MNDNR
RandallSounhein
Hello:
Was curious - did you ever get this resolved?  Also if your editing in ArcSDE you will need to make sure that the service you created has Feature Access ie needs to be a Feature Service.
Randy
[email protected]
BeckyCarr
also unable to apply edits. published feature service, 10.1. 3.6 flex. lets me add text, but does not update source data. sql database is versioned. permissions read/write.
GeorgeHaskett
Becky did you ever resolve this?
Have you set up your gdbversion and iseditable attributes?
http://resources.arcgis.com/en/help/flex-viewer/concepts/index.html#/Dynamic_Tiled_Feature_and_Image...
