I'm currently attempting to access a secured REST service using Flex 2.5. I've generated several tokens and initially they seem to work just fine. Then at some point they appear to not be valid any longer. I've set the expiration to 365 Days also tried 525600 Min (which is the equivilent of 365 days). As there doesn't appear to be any set pattern as to when the token expires, I've been trying many different possible solutions, all of which have been unsuccessful.
I've had the Host of the server check thier options for long term tokens and it's set correctly.
I've tried using different combinations of times that are equivelant to 365 days (thus the 525600 minutes).
Looked into the crossdomain.xml, but if I'm understanding correctly that would be on the server end and not the user. And since I'm told other people are able to use this service without issue, I doubt its the crossdomain.xml.
I'm attached a copy of the error that I'm recieving. If anyone can think of any other possible solutions, I would much appreciate the assistance.
