TOC Widget v.3.2 - won't stop "Generating Legend"
1375
04-17-2013 09:18 AM
AlisonPage
I can't get the little wheel icon and "Generating Legend" to stop going when I open my TOC widget. Any thoughts? I'm using v3.2.
Alison
RobertScheitlin__GISP
Alison,
   That can happen if one of your map services is failing to load for some reason. You need to use a HTTP utility like fidler or charles and see if one of your services is failing to load.
Alison,
AlisonPage
So, it looks like it's one of my external layers.. it says "Layer type is not supported" when I open the Map Service into ArcMap from the below URL and analyze the map...
http://137.227.242.85/ArcGIS/rest/services/Wetlands/MapServer
Thanks for the information. I'll contact them and see if they have a new Map Service.
-Alison
AlisonPage
In case anyone else was using the National Wetlands Inventory Map service... they have a newer one that's v.10.1 instead of 9.3:
http://107.20.228.18/ArcGIS/rest/services/Wetlands/MapServer
Changing to the newer URL has fixed my "Generating Leged" issue.
Alison
