TOC v2.5 - shrinking space between legend and layer name?
1258
06-13-2012 03:09 PM
ChristinaLaurier
Hi again,
Still working on some formatting issues.
I have noticed that our sub-layer names within some map services are very long and run into the TOCmenu (transparency, collapse all, description, etc).
In the TocItemRenderer.as:
-I changed
            // UI component spacing
     private static const PRE_CHECKBOX_GAP:Number = 5;     // changed to 2
     private static const POST_CHECKBOX_GAP:Number = 4;  //changed to 1
I have also found the spot to decrease the space between the legend symbol and the layer label
In TocItemRenderer.as
     override protected function updateDisplayList(unscaledWidth:Number, unscaledHeight:Number):void
if (_group && _group.numElements > 0 && _group.visible)
    _group.setActualSize(_group.contentWidth, _group.contentHeight);
    _group.x = startx;
    _group.y = (_group.height > 0)?(unscaledHeight - _group.height) / 2 : 4;
    startx = _group.x + 30 + POST_CHECKBOX_GAP;
Unfortunately, changing the value less than 30 does not work for our application because some symbols need this amount of space.
How would I go about removing the extra TocMenu (i.e. collapse/expand all, transparency,  move down, description)?
ChristinaLaurier
Got it,
Just removed the TocLayerMenu.mxml  & then commented out errors
RobertScheitlin__GISP
Christina,
   Hmmm... why didn't you just increase the width of the widget.
Robert
