TOC checkbox behavior after 3.1
1584
04-09-2013 10:35 AM
KennyHoran
I've noticed that TOC checkboxes behave differently with nested layers in 3.1.  It's rather hard to explain but when you see it in action it's very awkward.  Say you have a tree structure like this:
A
-B
--C
--D
In 3.0 and earlier you could check or uncheck any layer at any time.  Nice and simple.
In 3.1 this behavior has changed.  Now a layer can only be checked if one of its sublayers are checked.  This forces the user to expand the tree to its lowest level and check backwards.  In addition, a parent layer will automatically uncheck when all of its children are unchecked.  The top layer however (A) follows the 3.0 behavior and can be toggled at will.
It's extremely awkward and makes navigation difficult.  Add more sub-layers and it gets even messier.  Please, please bring back the old behavior from 3.0.
SarthakDatt
Hi Kenny,
Thanks for reporting this. We will have a fix for the next version(3.3).
If you are working with un-compiled version of the Viewer, you can look here:
https://github.com/Esri/arcgis-viewer-flex
https://github.com/Esri/arcgis-viewer-flex/issues/102
Hope that helps.
SarthakDatt
Hi Kenny,
Hope that helps.
