Thematic Map Widget not working?
1653
08-21-2012 07:39 AM
FranciscoCaldeira
It looks like the thematic Map widget is not working in Arcgis Flex version 3.0. When I click on a feature I should be able to see a infowindow insteed of this error message.
http://resources.arcgis.com/en/help/flex-viewer/live/index.html?config=apps/config-thematic.xml
TypeError: Error #1009: Cannot access a property or method of a null object reference.
at mx.charts.chartClasses::ChartBase/initStyles()
at mx.charts.chartClasses::ChartBase/set moduleFactory()
at mx.charts.chartClasses::CartesianChart/set moduleFactory()
at mx.charts::ColumnChart/set moduleFactory()
at mx.core::UIComponent/http://www.adobe.com/2006/flex/mx/internal::addingChild()
at mx.core::Container/http://www.adobe.com/2006/flex/mx/internal::addingChild()
at mx.core::Container/addChildAt()
at mx.core::Container/addChild()
at mx.core::Container/createComponentFromDescriptor()
at mx.core::Container/createComponentsFromDescriptors()
at mx.core::Container/createChildren()
at mx.core::UIComponent/initialize()
at mx.core::Container/initialize()
at mx.core::UIComponent/http://www.adobe.com/2006/flex/mx/internal::childAdded()
at mx.core::UIComponent/addChildAt()
at spark.components::Group/addDisplayObjectToDisplayList()
at spark.components::Group/http://www.adobe.com/2006/flex/mx/internal::elementAdded()
at spark.components::Group/setMXMLContent()
at spark.components::Group/createChildren()
at mx.core::Container/http://www.adobe.com/2006/flex/mx/internal::childAdded()
at widgets.Samples.ThematicQuery::InfoColumnChartWidget/initialize()
at spark.components::Group/addElementAt()
at spark.components::Group/addElement()
at com.esri.ags.components.supportClasses::InfoWindow/commitProperties()
at mx.core::UIComponent/validateProperties()
at mx.managers::LayoutManager/validateProperties()
at mx.managers::LayoutManager/doPhasedInstantiation()
at mx.managers::LayoutManager/doPhasedInstantiationCallback()
I'm using this Widget in a custom aplication but I'm experiencing the same problem. Is it just me or anyone noticed the same problem?
Kind regards
Francisco Caldeira
RobertScheitlin__GISP
Francisco,
  You are not the only one seeing this. Maybe the viewer team will see this and get it fixed for the next release.
MehulChoksey
Thanks for reporting this. Following workaround (for flex sdk 4.6 regression) will be added in the next release of the viewer..
Add to InfoColumnChartWidget.mxml following funtions:
private function basewidget_preinitializeHandler(event:FlexEvent):void
                // work-around for 4.6 regression
                copyStyleFromParent("mx.charts.chartClasses.ChartBase");
                copyStyleFromParent("mx.charts.chartClasses.CartesianChart");
                copyStyleFromParent("mx.charts.chartClasses.PolarChart");
                copyStyleFromParent("mx.charts.BarChart");
                copyStyleFromParent("mx.charts.ColumnChart");
                copyStyleFromParent("mx.charts.LineChart");
                copyStyleFromParent("mx.charts.PieChart");
                copyStyleFromParent("mx.charts.AxisRenderer");
                copyStyleFromParent(".blockCategoryAxis");
                copyStyleFromParent(".blockNumericAxis");
                copyStyleFromParent(".linedNumericAxis");
                copyStyleFromParent(".dashedNumericAxis");
                copyStyleFromParent(".dashedCategoryAxis");
                copyStyleFromParent(".hangingCategoryAxis");
                copyStyleFromParent("mx.charts.GridLines");
                copyStyleFromParent(".horizontalGridLines");
                copyStyleFromParent("mx.charts.series.BarSeries");
                copyStyleFromParent("mx.charts.series.ColumnSeries");
                copyStyleFromParent("mx.charts.series.LineSeries");
                copyStyleFromParent("mx.charts.series.PieSeries");
            private function copyStyleFromParent(selector:String):void
                var chartBaseStyle:CSSStyleDeclaration = styleManager.getStyleDeclaration(selector);
                if (!chartBaseStyle && styleManager.parent)
                    var parentStyle:CSSStyleDeclaration = styleManager.parent.getStyleDeclaration(selector);
                    if (parentStyle)
                        styleManager.setStyleDeclaration(selector, parentStyle, false);
and update following:
<viewer:BaseWidget xmlns:fx="http://ns.adobe.com/mxml/2009"
                   xmlns:s="library://ns.adobe.com/flex/spark"
                   xmlns:mx="library://ns.adobe.com/flex/mx"
                   xmlns:viewer="com.esri.viewer.*"
                   creationComplete="init()"
                   preinitialize="basewidget_preinitializeHandler(event)"
                   implements="com.esri.viewer.IInfowindowTemplate">
MehrshadNourani
Hello,
Is there a new release available for Thematic Map Widget?
Mehrshad
BjornSvensson
Esri Alum
It is still available as a sample:
https://github.com/Esri/arcgis-viewer-flex/tree/master/src/widgets/Samples/ThematicQuery
