Text Box for Flex Viewer 3.6?
3533
07-18-2015 08:12 AM
TimHayes
I need a Text or Info Box (floating) that a user can drag around the map window. This Text Box would contain brief written instructions on how to do a specific procedure. It would not change. It is just there for user reference and can be moved around out of the way if needed (floating).
I do not want to use the Splash Screen because it will annoy my users because they need to click ok all the time before they use the application. I just need something they can see when they first open the UI, but can still use the map viewer without having to click OK.
Is there a widget out there that can do this?
TimHayes
Ok, I just had a chance to take a gander at Robert's eSplash Widget. You can move it around! it's a floating window! this will work for me. Unless someone else has a better idea?
Thanks again, Robert, for bailing me out!
RobertScheitlin__GISP
Tim,
   A couple of people has used my eSplash for such purposes. I don't know of a better route beside some custom development.
