Tabs in Pop-Up for feature
2526
01-23-2012 10:58 AM
AmySadler
I am trying to configure the pop-up viewer for point features to have two different tabs: one where basic information would show and another where reports linked to those features would be. I have all the information I need for these tabs in the pop-up as it is, but it is crowded bc there is a lot of information on one display. I'm really new to Flex and have basically just been configuring the viewer from ESRI, so any insight would be much appreciated!
Thanks!
Amy Sadler
RobertScheitlin__GISP
Amy,
   This would require a pretty in depth change to the PopUpRendererSkin.mxml. Do you have Flash builder and time to learn flex enough to make these changes? General guidance could be provided but as your data is no doubt unique to you it will require you to know enough actionScript and Flex to make these changes to the Viewer.
AmySadler
Thanks for your help! I do not have the time or the willpower to do all that just yet! 🙂
Also, had no idea someone had responded to this post...I need to set up the notification.
Thanks anyways!
Amy
JanPacina
Hi there,
the tabs are well used in the Advanced Splash widget. May be there is some simple way to rewrite the code ...
Jan
