Table of Contents - Legend Widget for FlexViewer 2.x
186649
664
12-01-2010 07:30 AM
RobertScheitlin__GISP
All,
Here is the next in my line of widgets for the FlexViewer 2.x.
The legend portion of this widget is the same code as my dynamic legend widget so,
IT IS FOR ARCGIS SERVER 10 OR GREATER ONLY
This is just a simple TOC Widget that includes my dynamic legend component.
This widget also includes my enhancement for map service transparency,
right click context menu for zoom to make layer visible, and my scale
dependent renderer for the TOC checkboxes.
GaryWine
Very nice tool
However; I am attempting to adjust it's display location. The task looks pretty simple after looking at the code, but I am not able to move the widget to the right side of the display. I am attempting to place it right="20" top="70", but it is not moving. Is there something I am missing, or is the a locked feature.
Jeff Frye
Berkely County, WV
PaulFerro1
Jeff,
right="90" top="25" works for me.
is your widgecontainer set to: <widgetcontainer layout="float">
Paul,
   It would have to run some code like this:
            private function expandAll(item:TocItem):void
                item.collapsed = false;
                _toc.expandChildrenOf(item, true);
                if(item.isGroupLayer()){
                    for each (var item2:TocItem in item.children){
                        expandAll(item2);
I don't have time to help with much more.
PaulFerro1
Thanks Robert for the help!
On what line of the TOCWidget.mxml would I place it?
Paul,
   It would not go in the TOCWidget.mxml. It would likely need to go into the TOCMapLayerItem.as, but as I said I don't have to time to help you with this customizations specifics.
GaryWine
Thanx Geo - I never considered looking at that.
RhettZufelt
MVP Notable Contributor
Hi Robert,
I am using v 2.5 of your TOC. I have written some html in my layer description in ArcMap, then published it as a service.  I want to include hyperlinks in the Details/Description window. See attached screen shot.
My html code is [HTML]<p>For more information, go to: <a href="http://www.oregon.gov/DOGAMI/pages/earthquakes/coastal/tsumaps.aspx" target="_blank"><span style="color:#FFD700">OREGON.gov</span></a></p>[/HTML]
I want to change the hyperlink color to gold, but it's not coming through the swf. file and retains the default blue for the hyperlink. I assume I need to recompile the TOC widget.  Do you know where it the DetailsWindow.mxml I can change the default hyperlink
color?  Thanks so much.
I'm curious as to how you got the description to show in the little window.  For me, it opens up the mapservice page in a new browser window.
R_
Rhett,
   That is controlled by this tag in the TOCWidget.xml
<usenewesridescription>false</usenewesridescription>
RhettZufelt
if I set that to false, then I do not get the "description" option in the drop down.
If I set it to true, then I get this when i click on it:
[ATTACH=CONFIG]16962[/ATTACH]
istead of the nice little popup looking window from previous post.
R_
Rhett,
   That is because your Service description for your map service is blank, so there is nothing to show.
