Table of Contents - Legend Widget for FlexViewer 2.x
199258
664
12-01-2010 07:30 AM
RobertScheitlin__GISP
All,
Here is the next in my line of widgets for the FlexViewer 2.x.
The legend portion of this widget is the same code as my dynamic legend widget so,
IT IS FOR ARCGIS SERVER 10 OR GREATER ONLY
This is just a simple TOC Widget that includes my dynamic legend component.
This widget also includes my enhancement for map service transparency,
right click context menu for zoom to make layer visible, and my scale
dependent renderer for the TOC checkboxes.
JeremyMoore
Hey Robert,
Does the getLegend work for layers requiring a Proxy? Any layer that is using a proxy doesn't seem to return the legend image.
Jeremy,
   I don't use Proxies and there for have not developed to support them.
JeremyMoore
Jeremy,
Thanks. I'll see if I can put the proxy request in for the legend request and send it to you if you want.  Thanks for all the widget support over the years!
JeremyMoore
I added proxy support if you want the code. Thanks again
Jeremy,
  Absolutely. Thanks
SaugatJoshi
Hi Robert Thanks for the comment. How can I gain access to the older version of this widget? I am looking for 2.3.9.1 i.e I beleive just before flexViewer  2.4 release.
Thanks.
Saugat,
   With as many widgets as I support and constantly updating those widgets, I can not keep old versions of the source code. I do have the last compiled version which was 2.3.9.2. I do not have the source code of this version though.
MaxNos1
I can not change the label " Layer Visibility". modify in TOCWidget.xml <visibilitylabel>Layer Visibility</visibilitylabel> to <visibilitylabel>My Label</visibilitylabel> but nothing happens... In what may be the problem?
Max,
   This is now fixed in version 2.4.5.
MaxNos1
Max,
thank you!!!
