Table of Contents - Legend Widget for FlexViewer 2.x
184208
664
12-01-2010 07:30 AM
RobertScheitlin__GISP
All,
Here is the next in my line of widgets for the FlexViewer 2.x.
The legend portion of this widget is the same code as my dynamic legend widget so,
IT IS FOR ARCGIS SERVER 10 OR GREATER ONLY
This is just a simple TOC Widget that includes my dynamic legend component.
This widget also includes my enhancement for map service transparency,
right click context menu for zoom to make layer visible, and my scale
dependent renderer for the TOC checkboxes.
Stuart,
   The ability to remove the Transparency slider will be in the next version.
StuartBlumberg
Thank you Robert.
GauravMaske
Thank you Robert.
RoiMartinez
Hello! I was reading all the thread and I though that the problem with the metadata icon position was solved in the last released version.
But when I launch my Viewer, in the TOC Widget, the metadata icon overlap the layer name. Even when I resize the widget remains with the same width the layers content and metadata icon position.
only happens to me?
Thanks a lot in advance!
RoiMartinez
Hello again,
My provisional solution was incrementing the width in TOCWidget.mxml. But could be possible that the icon appears at the end of each layer name instead a fixed distance for all the icons?
thanks
Roi,
    That is a know issue with no current resolution right now. Keep checking back for new version.
DanDowning
Andrew,
   I don't know what the issue is YET but I am now looking into it. Hopefully I can resolve it soon.
Thanks for letting me know.
I am having a very similar issue to Andrew except with the TOC widget. Opening the last layer group causes the flash container executable (plugin-container.exe) to consume 100% CPU time and hemorrhage memory until it crashes.
Here is the site: http://oscar.geoplan.ufl.edu/flexviewer_2.3.1/
Thanks for all the great widgets Robert!
Danny
Dan,
   Your posted url only give a proxy error.. But it don't really matter as this issue is still unresolved. There is a workaround that I have found for now though. Just put a simple symbol layer as the last layer in the toc and it works fine.
GarrettMoeller
Greetings,
I have been using the TOC widget successfully since the beginning of the year in a flexviewer app (compiled).
I see that there have been many updates since then.
Where do I go to get the latest update?
Also, I am curious whether it is possible to have the widget default to the legend instead of the layer list.
Thank you,
Garrett Moeller
Garrett,
  Same place you got it from the first time:
http://www.arcgis.com/home/item.html?id=e2cb71d5c04d40d19e9f945ae0db7ce8
You will notice that the legend is now integrated with the toc they are no longer to separate parts.
