Symbolizing layers on AGS 9.3 in Flex Viewer v2.2
3287
26
03-18-2011 10:16 AM
ChristinaKepler
I'm using the latest v2.2 of the Flex Viewer against v9.3.1 of AGS. In my viewer, I'm using a FeatureLayer as follows:
<layer label="Wells" type="feature" visible="true" alpha="1"
                   info="widgets/InfoTemplates/SimpleInfoWinWidget.swf"
                   infoconfig="widgets/InfoTemplates/Wells_Simple.xml"
                   url="http://myServer/ArcGIS/rest/services/myService/MapServer/0"/>
The reason for this is so that I can leverage the InfoWindow functionality in the viewer, which doesn't work when the layer 'type=dynamic'.
Everything works as expected, but the layer is being symbolized with black circles (looks like a default setting) instead of the symbology from the server, as it does w/ AGS v10.
Question:  Is there a way to mimic the server-side symbology on the Flex client when using the v2.2 viewer against a v9.3.x service?
RobertScheitlin__GISP
Alison,
   A couple of questions.
  1. Your attribute field "PHOTO" is a string field that contains values like "Y" and "N"?
  2. The layer with type="feature" that you are trying to symbolize has a label of "NEP_Projects" in your main configuration file? and looks something like this:
    <layer label="NEP_Projects" type="feature" visible="true"
  3.                    url="http://your server/ArcGIS/rest/services/yourService/MapServer/0"/>
  4. I am not sure what this is talking about...
    And in my xml file, I've added the following in the opening configuration tag:
  5. <configuration label="NEP_Projects">
AlisonPage
Hi Robert,
1. Yes, PHOTO is a field in my map service with the value or Y or N.
2. I obviously put the label in the wrong place.  I thought it was to go into the xml file for the popupconfig instead of in the feature layer tag in the main config.
I'll change that and give it another try. Thanks so much!
-Alison
AlisonPage
That worked for showing the symbology on the map but it doesn't change them in the Map Contents widget (screenshot below). Any thoughts on how I can get them to show up in the widget?
Alison
AlisonPage
Anyone have any thoughts on why the symbols listed in my mapmanager.mxml aren't showing up in my map contents widget? Screenshot is in the last post above.
Alison,
   The TOC/Legend widget is only going to display what ArcGIS Server is returning and not what you are overriding in the map manager.
AlisonPage
So I should add the same symbology to my mapservice?
Alison,
    Yes. That is it exactly and if you do that then there is really no need for the MapManager code change.
