Stop header controller search using default geocoder
3500
07-04-2013 03:01 PM
HaroldJohnson
I apolgise if this has been answered before but i have looked and cannot see the answer anywhere. I have set up the search box in the header controller to search against a layer in one of my map services but it always searches using a geocode service on arcgis.com as well. Is there a way to stop this.
Any help appreciated, I am using the compiled version on 3.3
AnthonyGiles
Honored Contributor
Harold,
You need to add a usemapservicesonly tag with a value of true in between your geocoder tags, ie:
<geocoder>   <usemapservicesonly>true</usemapservicesonly> </geocoder>
See the help here:
http://resources.arcgis.com/en/help/flex-viewer/concepts/index.html#/Header_Controller_widget_tags/0...
Regards
Anthony
AnthonyGiles
Honored Contributor
Harold,
See the help here:
Regards
Anthony
HaroldJohnson
Thanks Anthony that did the trick
