SOAP interface for flex viewe
801
02-25-2011 11:22 AM
SaugatJoshi
Hi, I have created mapping services using ArcGis server. The services are available as SOAP or Binary. I am quite not sure if the current flex viewer can take SOAP.Is there anyway to have it as a REST endpoint?
Thank you.
RobertScheitlin__GISP
Saugat,
   If you are using ArcGIS Server 9.3 or greater than you have the ability to use REST just run the web services post install.
