Shifted polygons using eSearch
760
02-19-2014 08:22 AM
EmilioSolano
Hi Robert,
I just found this odd behavior: I searched a parcel using eSearch Widget version 3.6.1 (12/19/2013)  then identified the same parcel using Identify Widget version 3.6.4 (2/13/2014),all these running on Flexviewer 3.6, and I noticed that the highlighted polygon fill (in red) was shifted on the X and Y directions, while the same identified polygon (in blue) was in the right place. This is the first time it happens since I started using your fine widgets, about a couple years ago.
Both widgets are searching and identifying the same parcel from the same layer. Any ideas why is this happening? I haven't searched the forum to see if someone else had the same issue yet. Thanks.
Emilio
RobertScheitlin__GISP
Emilio,
  In my initial testing of the same exact version of both widgets, I have not been able to reproduce what you are seeing. What is the WKID of your data and what is the WKID of the map?
