SETTING YOUR ZOOM IN MAXIMUM ON DATA
3627
6
04-11-2011 08:00 AM
MatthewBaker1
I currently have some images that ihave added to my flexviewer application.  My question is how do i set the zoom in amount for my images.  they are HD images and I would like to be able to zoom in pretty close on them when they are viewed from the Flex viewer application.  How do i set that zoom level for these images?
JonathanWatson
If you are using FlexViewer 2.2, use the <lods> tag like in the following post:
http://forums.arcgis.com/threads/23820-ArcGis-Flex-viewer-2.2-Zoom?p=85423&viewfull=1#post85423
TomMagdaleno
How do you do this for version 3.0 of the flexviewer?  Do I do it on my computers config.xml or on the server?  I see config.xml folders on both.  On the server their is nothing in it.  On my computer I don't see any of the syntax mentioned to insert the code.  Could someone shine some light on this?
TomMagdaleno
subscribed
RhettZufelt
MVP Notable Contributor
version three supports LOD as well.
http://resources.arcgis.com/en/help/flex-viewer/concepts/index.html#/Main_configuration_file/01m3000...
either set the LOD's you want to see, OR, load a tiled basemap with the LOD cache levels as the first basemap.
R_
RhettZufelt
Are you using compiled or source code version?
TomMagdaleno
I figured out from ESRI that you need to cache scales on your basemap to zoom in closer.  So if you smallest scale is 1:1000 and you need to zoom in more add a 1:600 cache scale.
