set ArcGISDynamicMapServiceLayer properties
2346
11-29-2012 05:07 PM
RhettZufelt
MVP Notable Contributor
I am utilizing the following code from the MapServicesWidget:
case "dynamic":
  var dynLayer:ArcGISDynamicMapServiceLayer = new ArcGISDynamicMapServiceLayer(url);
  dynLayer.alpha = alpha;
  dynLayer.id = label;
  dynLayer.name = label;
  dynLayer.token = token;
  dynLayer.visible = visible;
  dynLayer.useMapTime = useMapTime;
  dynLayer.sublayerid = sublayerid ;
  dynLayer.popupconfig= popupconfig;
  if (autoRefresh > 0)
   setInterval(dynLayer.refresh, autoRefresh * 1000);
  if (imageFormat)
   dynLayer.imageFormat = imageFormat;
  if (visibleLayers)
   var vizLayers:Array = visibleLayers.split(",");
   for (i = 0; i < vizLayers.length; i++)
    vizLayers = Number(vizLayers); // convert to Numbers
   dynLayer.visibleLayers = new ArrayCollection(vizLayers);
  if (proxyUrl && useProxy)
   dynLayer.proxyURL = proxyUrl;
  map.addLayer(dynLayer);
  break;
This allows me to pick from a list, and load the service into the current map.
Was wondering if there is a way to set the popupconfig file to use for each sublayer (similar to the config.xml file) so that when i load the service with the widget (something like in red above), it will recongnize the appropriate popupconfig.xml file?
Thanks for any suggestions,
R_
AnthonyGiles
Honored Contributor
RhettZufelt
Bump...
No ideas?
Still no way to define the popup config file for layers added programtically?  Maybe and enhancement in 3.2?
Still hoping,
R_
AnthonyGiles
Honored Contributor
Rhett,
Does this thread give you any pointers?
http://forums.arcgis.com/threads/79733-Enable-default-popups-for-user-added-layer
Regards
Anthony
RhettZufelt
Thanks Anthony,
That was good timing, had not seen that new post yet.
This should help get me on the way.
R_
