set a value on HeaderController...textbox
1194
06-06-2014 05:44 AM
NatashaManzuiga
Hi, I'm trying to set a value in text box inside the Header Controller from the SearchWidget:
var id:Number = ViewerContainer.getInstance().widgetManager.getWidgetId("HeaderController");
var bWidget:IBaseWidget = ViewerContainer.getInstance().widgetManager.getWidget(id, true) as IBaseWidget;
It works for other widgets...but I get nothing with HeaderController....
Can u help me?
Naty
NatashaManzuiga
Nobody can help me?
I still try but no success... 😞
Naty
RayCrew
Are you just looking for the to change the search prompt text?To do that, you just need to add the following:
<labels>
     <searchprompt>Search Prompt Text</searchprompt>
</labels>
NatashaManzuiga
<labels>
</labels>
It is not the Search Prompt Text..My problem is that on runtime I need to get a value from Search Results and I want to set it in the input box of the HeaderController....And I'm trying and trying without success....:confused:
I hope someone can help me...
Naty
NatashaManzuiga
Naty
I used this function and I got the widget..
Naty
   // Get UI Widget by Label.....,. (Make controlContainer PUBLIC)
   public function getUIWidget(widgetLabel:String):IBaseWidget
    for (var x:Number = 0; x < controlContainer.numElements; x++)
     var widget:IBaseWidget = controlContainer.getElementAt(x) as IBaseWidget;
     if (widget.widgetTitle.toUpperCase() == widgetLabel.toUpperCase())
      return widget;
    return null;
