Selection Widget Updated Version
79475
146
05-12-2011 05:24 AM
MarkHoyland
The Selection widget has a "Select by Attributes" and "Select by Location" option similar to ArcGIS.
Widget link: http://www.arcgis.com/home/item.html?id=20ed6af9ab204548bbf092d51b51fef8
Version 1.5 of the widget replaces version 1.0
Enhancements and fixes include:
*Each time a query layer was added it was also being added to the TOC. This has been fixed.
*When resizing the widget, the datgrid would not resize properly. This has been fixed.
*Uses paging for selection of unique value list. This means that ALL values will be parsed regardless of the ArcGISServer setting to limit responses. There is an option to ESC out of a large query. (This is only for the Unique list, not getting features).
I have included an ESRI TaxParcel Layer that has 18,000+ records. Get Unique Values on the PSTLSTATE field to see this in action.
Available on my example site. The URL is on the Widget download page.
*Aliases can now be used. It will now use the Alias as set in the Featureclass. You can also override the Alias in the SelectionWidget.xml config file.
*ArcGis layers that have joined tables will now work with fully qualified field names. (thanks Dasa for the idea)
*Styling for selection colours has been documented in the SelectionWidget.xml config file (example provided).
*Styling for datagrid has been changed. It can now also be styled in SelectionWidget.xml config file (example provided). (thanks Mehul for the idea)
*Changed initial uniquevalue query to use "text='%'" instead of "where '1=1'" for Mike.:)
*You can now override scale range for layers.
*Link field now has a prefix/suffix option in the SelectionWidget.xml config file (naming convention the same as Robert SCheitlin's esearch widget)
*Shape_area and Shape_length can be used in the fields.
Link to previous thread :http://forums.arcgis.com/threads/24151-Selection-Widget-for-SFV2.2-(with-a-query-builder)
LefterisKoumis
Attached is compiled for 3.6.
francescodi_vito
Great
Inviato da iPhone
Il giorno 05/mar/2015, alle ore 18:47, Lefteris Koumis <[email protected]> ha scritto:
reply from Lefteris Koumis in ArcGIS Viewer for Flex - View the full discussion
Reply to this message by replying to this email, or go to the message on GeoNet
Start a new discussion in ArcGIS Viewer for Flex by email or at GeoNet
Following Selection Widget Updated Version in these streams: Inbox
This email was sent by GeoNet because you are a registered user.
You may unsubscribe instantly from GeoNet, or adjust email frequency in your email preferences
KummerLaszlo
This is exactly what I was looking for.
Thank you all for your help.
One thing occured to me. There is a reference to InfoPopupWidget.swf at the end of the xml config file.
Do I have to replace that swf to a 3.6 version? I mean now it seems that it works flawlessly but I don't know if it can cause any problems in the future.
LefterisKoumis
You can use the same infopopupwidget.
KummerLaszlo
Ok.
Thank you again for your help.
by Anonymous User
Not applicable
has anyone ported this or created something like this for the Javascript API? Especially as a Widget for WebApp Builder?
by Anonymous User
Not applicable
update: I found an example and I am commencing work...Kevin Custom WAB Widgets
