Selection Widget Updated Version
79478
146
05-12-2011 05:24 AM
MarkHoyland
The Selection widget has a "Select by Attributes" and "Select by Location" option similar to ArcGIS.
Widget link: http://www.arcgis.com/home/item.html?id=20ed6af9ab204548bbf092d51b51fef8
Version 1.5 of the widget replaces version 1.0
Enhancements and fixes include:
*Each time a query layer was added it was also being added to the TOC. This has been fixed.
*When resizing the widget, the datgrid would not resize properly. This has been fixed.
*Uses paging for selection of unique value list. This means that ALL values will be parsed regardless of the ArcGISServer setting to limit responses. There is an option to ESC out of a large query. (This is only for the Unique list, not getting features).
I have included an ESRI TaxParcel Layer that has 18,000+ records. Get Unique Values on the PSTLSTATE field to see this in action.
Available on my example site. The URL is on the Widget download page.
*Aliases can now be used. It will now use the Alias as set in the Featureclass. You can also override the Alias in the SelectionWidget.xml config file.
*ArcGis layers that have joined tables will now work with fully qualified field names. (thanks Dasa for the idea)
*Styling for selection colours has been documented in the SelectionWidget.xml config file (example provided).
*Styling for datagrid has been changed. It can now also be styled in SelectionWidget.xml config file (example provided). (thanks Mehul for the idea)
*Changed initial uniquevalue query to use "text='%'" instead of "where '1=1'" for Mike.:)
*You can now override scale range for layers.
*Link field now has a prefix/suffix option in the SelectionWidget.xml config file (naming convention the same as Robert SCheitlin's esearch widget)
*Shape_area and Shape_length can be used in the fields.
Link to previous thread :http://forums.arcgis.com/threads/24151-Selection-Widget-for-SFV2.2-(with-a-query-builder)
KummerLaszlo
Here You are:
[ATTACH=CONFIG]27926[/ATTACH]
[ATTACH=CONFIG]27927[/ATTACH]
Where can I find the compiled 3.5 version of this widget?
Or could someone compile them for me.
Thank You
BrianKratcha
Does anyone have this working for 3.6?
Will this widget be added to the core group of widgets in the future?
Brian
RobertScheitlin__GISP
Brian,
   The original developer is no longer updating this widget. I don't use the widget. I doubt that the Flex team is considering this as an addition to the core widgets.
PiotrSkworzec
So, what is an alternative for selection widget? I just want to have similar utility as select (location, attributes) in arcgis desktop.
Piotr,
   There really isn't one that is like ArcMap besides this one, that is no longer maintained. The closest is the eSearch widget that I have been maintaining for years now. http://www.arcgis.com/home/item.html?id=5d4995ccdb99429185dfd8d8fb2a513e
PeterHoffman
Does anyone have explanations of the SelectionWidget.xml options available?
KummerLaszlo
Does anyone have a compiled version that works with 3.6 or 3.7?
francescodi_vito
Spero but i don't have
Inviato da iPhone
Il giorno 05/mar/2015, alle ore 15:16, Kummer Laszlo <[email protected]> ha scritto:
reply from Kummer Laszlo in ArcGIS Viewer for Flex - View the full discussion
Reply to this message by replying to this email, or go to the message on GeoNet
Start a new discussion in ArcGIS Viewer for Flex by email or at GeoNet
Following Selection Widget Updated Version in these streams: Inbox
This email was sent by GeoNet because you are a registered user.
You may unsubscribe instantly from GeoNet, or adjust email frequency in your email preferences
LefterisKoumis
Hi. Are you referring to this widget?
francescodi_vito
Yes.
Inviato da iPhone
Il giorno 05/mar/2015, alle ore 16:41, Lefteris Koumis <[email protected]> ha scritto:
reply from Lefteris Koumis in ArcGIS Viewer for Flex - View the full discussion
https://community.esri.com/servlet/JiveServlet/downloadImage/2-463158-68645/pastedImage_0.png
