Selected Features color
767
07-21-2011 12:10 PM
LonSharp
I'm new to flex, so appologies if I'm missing something obvious.
I'm looking for a way to change the way selected features are highlighted in the viewer.   The default is a heavy red outline with a transparent red fill.   What I want is something more akin to ArcGIS Desktop:  heavy cyan outline with no fill.
I've checked the help and have tried adding symbols to the search widget with "simplefillsymbol" and/or "outline" tags, but I'm clearly doing something wrong.
Here's what I have:
<?xml version="1.0" encoding="utf-8" ?>
- <configuration>
- <layers>
- <layer>
  <name>Lake County Parcels</name>
  <url>http://gispublic.co.lake.ca.us:8399/arcgis/rest/services/Parcels/MapServer/0</url>
  <expression>APN like '[value]'</expression>
  <textsearchlabel>Search by 8 digit APN [ Example: 00100101 or 001001%]</textsearchlabel>
  <titlefield>APN</titlefield>
  <linkfield />
- <fields all="false">
  <field name="APN" alias="APN" gridfield="true" />
  <field name="PARCEL" alias="Parcel Number" gridfield="true" />
  <field name="ACRES" alias="Calculated Acreage" gridfield="true" />
  <field name="ACRES_1" alias="Acreage from Assessor" gridfield="true" />
  <field name="BASE_ZONE" alias="Base Zoning District" gridfield="true" />
  <field name="ZONING1" alias="Full Zoning (1)" gridfield="true" />
  <field name="ZONING2" alias="Full Zoning (2)" gridfield="true" />
  <field name="ZONING3" alias="Full Zoning (3)" gridfield="true" />
  <field name="GP1" alias="General Plan (1)" gridfield="true" />
  <field name="GP2" alias="General Plan (2)" gridfield="true" />
  <field name="GP3" alias="General Plan (3)" gridfield="true" />
  <field name="JURISDICTI" alias="City/County" gridfield="true" />
  <field name="SUPERVISOR" alias="Supervisorial District" gridfield="true" />
  <field name="CENSUSTRAC" alias="2010 Census Tract" gridfield="true" />
  <field name="TRA" alias="Tax Rate Area" gridfield="true" />
  <field name="CRNTDOC" alias="Current Document #" gridfield="true" />
  <field name="DOCDATE" alias="Current Doc. Date" gridfield="true" />
  <field name="DESCR" alias="Description (Assessor)" gridfield="true" />
  <field name="MAILADD" alias="Owner Mailing Address" gridfield="true" />
  <field name="MAILCITY" alias="City" gridfield="true" />
  <field name="MAILST" alias="State" gridfield="true" />
  <field name="MAILZIP" alias="ZIP" gridfield="true" />
  <field name="SITUS1" alias="Parcel Address" gridfield="true" />
  <field name="SITUS2" alias="City/Town" gridfield="true" />
  <field name="BUILT" alias="Year Built (if available)" gridfield="true" />
  <field name="TAXYEAR" alias="Tax Year" gridfield="true" />
  <field name="TAXAMT1" alias="Property Tax (1)" gridfield="true" />
  <field name="TAXAMT2" alias="Property Tax (2)" gridfield="true" />
  <field name="PAYDATE1" alias="Pay Date (1)" gridfield="true" />
  <field name="PAYDATE2" alias="Pay Date (2)" gridfield="true" />
  <field name="LAND" alias="Assessed Land Value" gridfield="true" />
  <field name="GROWING" alias="Assessed Crop Value" gridfield="true" />
  <field name="STRUC" alias="Assessed Structure Value" gridfield="true" />
  <field name="FIX" alias="Assessed Fix. Value" gridfield="true" />
  <field name="PP" alias="Assessed PP Value" gridfield="true" />
  <field name="NETVAL" alias="Assessed Net Value" gridfield="true" />
  <field name="TRANSDOC" alias="Transfer Document #" gridfield="true" />
  <field name="TRANSDATE" alias="Transfer Document Date" gridfield="true" />
  </fields>
  </layer>
  </layers>
- <symbols>
- <simplefillsymbol>
  <color>00CCFF</color>
  <alpha>0.8</alpha>
  <width>2</width>
  </simplefillsymbol>
- <outline>
  <alpha>0.8</alpha>
  <width>2</width>
  </outline>
  </symbols>
  <zoomscale>2400</zoomscale>
  </configuration>
- <!--     See Search widget documentation at
    http://links.esri.com/searchwidget
Thanks!
RobertScheitlin__GISP
Lon,
   The correct syntax would be:
    <symbols>
        <simplefillsymbol color="0x00CCFF" alpha="0">
            <outline color="0x00CCFF" alpha="0.8" width="2"/>
        </simplefillsymbol>
    </symbols>
LonSharp
Perfect.  Thanks!
I'm still feeling my way along with all this; obviously syntax is something I need to figure out.
