selected feature still in special colour even if the query widget is closed
4448
03-03-2015 11:57 PM
KoseWong
In my query widget, I have a function to select feature on a layer. The selected feature will in special colour compare to other features in the same layer. But what I want is to display the selected feature in special colour only when the widget is opened. Any ideas.
My code for selecting feature as posted below:
var query:Query = new Query;
query.where = "POST_CODE LIKE '" + txt_PostCode.text + "'";
query.outSpatialReference = map.spatialReference;
query.returnGeometry=true;
queryTask.execute(query, new AsyncResponder(onResult, onFault));
function onResult(resultSet:FeatureSet, token:Object = null):void
  graphicsLayer.clear();
  if (resultSet.features.length == 0){
  Alert.show("No feature returned, please try again.","ATTENTION");
  }else{
      var finalExtent:Extent;
      var stGraphic:Graphic = resultSet.features[0];
      finalExtent = Polyline(stGraphic.geometry).extent;
      resultLineSymbol = new SimpleLineSymbol(SimpleLineSymbol.STYLE_SOLID, 0xFF0000, 0.7, 5);
      graphicsLayer.symbol = resultLineSymbol;
      for each (var graphic:Graphic in resultSet.features){
          stGraphic = new Graphic(graphic.geometry);
          graphicsLayer.add(graphic);
          finalExtent = finalExtent.union(Polyline(graphic.geometry).extent);
      map.extent = finalExtent;
function onFault(info:Object, token:Object = null):void
      Alert.show(info.toString());
Thank you.
RobertScheitlin__GISP
Kose,
  Just hide your graphicsLayer in the widgets close event and then show it when the widget is opened again.
            private function widgetClosedHandler(event:Event):void
                if (shareResults)
                    map.removeLayer(resultFeatureLayer);
                else
                    resultFeatureLayer.visible = false;
                stopWidgetTimer();
                hideInfoWindow();
               graphicsLayer.visible = false;
Kose,
                if (shareResults)
                else
                stopWidgetTimer();
                hideInfoWindow();
KoseWong
Hi Robert,
Thanks for the reply and sorry for the late response. I still got the following errors:
access of undefined property:
resultFeatureLayer
shareResults
stopWidgetTimer
hideInfoWindow
I will try to figure it out, thank you.
KoseWong
Hi Robert,
Got it worked, thank you!
