select in attribute table widget
1941
9
01-07-2013 09:37 AM
PeterHoffman
I cannot seem to get a select feature to work in the new attribute table widget. I can get the attributes to appear in the table and edit them but I cannot select on the map. Am I missing something?
SarthakDatt
Hey Peter,
Are you trying to select feature(s) by clicking on a row in the Attribute Table component or you want to click on the feature on the map, thereby selecting it and highlighting the same in the component?
PeterHoffman
I am trying to click on the feature on the map.
SarthakDatt
The AttributeTable component is implemented in a way that it reacts to selection on the feature layer. The feature(s) need to be explicitly selected as there is no such behavior built into the Viewer.
See:
http://resources.arcgis.com/en/help/flex-api/apiref/com/esri/ags/layers/FeatureLayer.html#selectFeat...
You can look at this api sample as well:
http://resources.arcgis.com/en/help/flex-api/samples/index.html#/AttributeTable/01nq00000089000000/
PeterHoffman
In other words I would have to modify the code to allow selection of the feature?
SarthakDatt
Yes.
There's another way, where if you have the Edit widget open alongside, it gives the capability of clicking on a feature and selecting it.
PeterHoffman
I do not want to use the edit widget as it allows moving the selected feature, I just want to edit the attributes.
SarthakDatt
You can set <updategeometry> to false in Edit widget's config:
<?xml version="1.0" ?>
<!-- If compiling this widget, make sure to add -keep-all-type-selectors=true to your compiler arguments in the FB project properties. -->
<configuration>
    <createoptions>
        <polygondrawtools>polygon,freehandpolygon,extent,autocomplete</polygondrawtools>
        <polylinedrawtools>polyline,freehandpolyline,line</polylinedrawtools>
    </createoptions>
    <addfeatures>true</addfeatures>
    <deletefeatures>true</deletefeatures>
    <toolbarvisible>true</toolbarvisible>
    <toolbarcutvisible>false</toolbarcutvisible>
    <toolbarmergevisible>false</toolbarmergevisible>
    <toolbarreshapevisible>false</toolbarreshapevisible>
    <updategeometry>false</updategeometry>
    <updateattributes>true</updateattributes>
</configuration>
PeterHoffman
I have another thread for this issue in the edit widget:
What I need is to set this layer specific. I want to limit editing one layer just to attributes. I have other layers that I need full editing.
SarthakDatt
Right now there isn't a way to do that per layer. Its all or none as it applies to the Editor component.
The only solution that I can think of right now is that if you are using a 10.1 service, you can publish it in a way where geometry updates are disabled.
See:
http://resources.arcgis.com/en/help/main/10.1/index.html#//015400000393000000
