SecurityError: Error #2122: Security sandbox violation: BitmapData.draw
1412
12-29-2010 11:59 AM
RobertScheitlin__GISP
Viewer or API Team,
   I ran into a interesting situation today playing with the FlexViewer. I used the Traffic Camera (query widget) and displayed some traffic camera results and then went to print the map and got this application error:
SecurityError: Error #2122: Security sandbox violation: BitmapData.draw: http://gislap134/FlexViewer2.2/index.swf/[[DYNAMIC]]/2 cannot access http://www.trimarc.org/images/snapshots/CCTV016.jpg. A policy file is required, but the checkPolicyFile flag was not set when this media was loaded.
Any ideas?
FernandoPanetta
I have the same problem today! There is a solution pleace?
Thanks Michele
FernandoPanetta
today I investigated for this problem and I discovered that possible solution: crossdomain.xml into server where are the pictures.
For exsample the picture of flicker use different crossdomain:
http://api.flickr.com/crossdomain.xml
http://farm1.static.flickr.com/crossdomain.xml
http://farm2.static.flickr.com/crossdomain.xml
http://farm3.static.flickr.com/crossdomain.xml
http://farm4.static.flickr.com/crossdomain.xml
For call the crossdomain you must set a "Security.loadPolicyFile(url)" !!
I have modify the infoPopupWidget for auto-load a crossdoamin.xml for every site (if crossdomain exsist into server) creating a function:
private function security():void
var str:String = data.link;
var myArr:Array = str.split("/");
var crossdomainUrl:String = myArr[0] +"//" + myArr[2] + "/crossdomain.xml"
Security.loadPolicyFile(crossdomainUrl);
I call this function in dataChangeHandler() function :
private function dataChangeHandler(event:FlexEvent):void
if (data == null)
return;
_title = data.title || "";
_content = data.content;
if (_content)
infoContent.visible = true;
//clear picture and link button
infoImage.source = "";
infoImage.visible = false;
infoImage.includeInLayout = false;
infoLink.visible = false;
infoLink.includeInLayout = false;
if (data.link)
security();
var link:String = data.link as String;
var pos:Number = link.length - 4;
var sfx:String = link.substr(pos, 4).toLowerCase();
if ((sfx == ".jpg") || (sfx == ".png") || (sfx == ".gif"))
infoImage.source = link;
infoImage.visible = true;
infoImage.includeInLayout = true;
else
infoLink.text = link;
infoLink.visible = true;
infoLink.includeInLayout = true;
This trips function for each site where is a crossdomain but I have a problem if there not exist !!
Any suggestions to solve the problem?
Thanks
Michele
