SecurityError: Error #2048: Security sandbox violation:
6828
8
10-06-2010 06:59 AM
RobertoFigueroa
Hi all,
I am trying to publish a FlexViewer 2.1 in from my local machine. I am using IIS 5.0. I have placed the crossdomain.xml under my web root (C:\Inetpub\wwwroot). The crossdomain.xml file includes the following:
<?xml version="1.0"?>
<!DOCTYPE cross-domain-policy SYSTEM "http://www.adobe.com/xml/dtds/cross-domain-policy.dtd">
<cross-domain-policy>
    <site-control permitted-cross-domain-policies="all"/>
    <allow-access-from domain="*"/>
</cross-domain-policy>
However, I am still getting the following error when trying to launch the viewer in IE:
SecurityError: Error #2048: Security sandbox violation: http://163.155.89.150/flexviewer/index.swf cannot load data from http://devn19/ArcGIS/rest/services/emili_ho_dev/MapServer?f=json.
at MethodInfo-4395()
at mx.rpc::Responder/fault()
at mx.rpc::AsyncToken/http://www.adobe.com/2006/flex/mx/internal::applyFault()
at mx.rpc.events::FaultEvent/http://www.adobe.com/2006/flex/mx/internal::callTokenResponders()
at HTTPOperation/http://www.adobe.com/2006/flex/mx/internal::dispatchRpcEvent()
at mx.rpc::AbstractInvoker/http://www.adobe.com/2006/flex/mx/internal::faultHandler()
at mx.rpc::AsyncRequest/fault()
at DirectHTTPMessageResponder/securityErrorHandler()
at flash.events::EventDispatcher/dispatchEventFunction()
at flash.events::EventDispatcher/dispatchEvent()
at flash.net::URLLoader/redirectEvent()
I have Adobe Flash Player 10 installed.....
Any idea on what is the problem? Any help would be greatly appreciated.
Thanks
Roberto
RobertScheitlin__GISP
Roberto,
   You need to use either the computer name or the IP and not both. It sees http://163.155.89.150 and http://devn19 as different machines.
RobertoFigueroa
Roberto,
They are indeed different machines: "163.155.89.150" is my local PC which is hosting the ArcGIS Flex Viewer and "devn19" is a corporate server where we have some published ArcGIS Server map services.
Roberto,
  OK in that case than the crossdomain.xml needs to be on the ArcGIS Server machine than in it's wwwroot directory.
RobertoFigueroa
Roberto,
Robert,
I copied the crossdomain.xml file to the webroot directory in devn19 and now everything works!!!!
Thank you very much for your help.
Regards
Roberto
NadeemShaukat
Robert,
Regards
Roberto
Roberto,
I am having the same error #2048 even after I have placed the crossdomain.xml file on the server's C:\inetpub\wwwroot folder. Can you help me?
Following are the contents of the Crossdomain.xml
<?xml version="1.0" ?>   <cross-domain-policy>
  <allow-access-from domain="*" />
  <site-control permitted-cross-domain-policies="all" />
  <allow-http-request-headers-from domain="*" headers="*" />
DasaPaddock
Can you try a tool like HttpFox to make sure that it's successfully accessing your crossdomain.xml file?
JamesOBrien
You probably haven't enabled directory browsing to make the file accessible.
Here is a blog post which describes error 2048 in detail:
http://geophyter.blogspot.com/2010/11/flex-sandbox-security-error-2048.html
RaufAhmad
I am having the same kind of issue with my Flex application. I tried the crossdomain.xml with the same settings as you had mentioned. But no luck. It still results in Error#2048 Sandbox security errors. also when I access the file from browser it return the cross domain file eg. http://www.yourwebsite.com/crossdomain.xml
please reply with any suggestion because my whole project getting late due to this issue.
thanks
