Secure WMS over HTTPS
5253
03-07-2012 04:49 PM
WillHughes1
Not sure how to format a secure wms in the Flex Viewer v. 2.5.
The layer tag in the config looks like this:
<layer label="POIS" type="wms" visible="true" alpha="1.0" visibleLayers="Hospitals" version="1.3.0" skipGetCapabilities="true"
   url="https://giswebservername/services/maps/WMS?SERVICE=WMS&request=GetCapabilities&version=1.3.0" />
This error message pops up below.
Map Manager Message
layer failed to load: Fault code: Channel.Security.Error
Fault info: Security error accessing url
Fault details: Destination: DefaultHTTPS
I can connect to this wms in ArcCatalog.
What am I doing wrong?
Thanks.
-Will
NeilMartinko
I just recently started with Flex, so I'm not too experienced, but I'll give it a shot.
First off, your URL looks incorrect...
You have too much stuff in it.  Delete everything past the question mark.  Especially the "request=GetCapabilities"...  That requests an XML file of what the WMS can supply, not an image.  I think the Flex app adds the service= and version= and other stuff to request the image it needs.  That's why you have...
type="wms" visibleLayers="Hospitals" version="1.3.0"
...in the layer definition.
Second, I have no idea if it can do WMS over HTTPS.  I'd try making it work with standard HTTP first, then try HTTPS if I really wanted it.
WillHughes1
I forgot to mention in the original post that PKI is enabled as well as SSL. Thanks. It looks like the default behavior of the flex viewer doesn't recognize when a wms is PKI enabled because it doesn't ask for my certificate when I load the viewer.
-Will
DasaPaddock
WillHughes1
Has anyone out there figured out how to insert secured wms (AFW-WEBS) into the flexviewer? I can see the wms services from within ArcCatalog, however, the services don't display in the flexviewer. I am pretty sure this is due the wms security since a certificate is required in order to view the services. Initially on load of my flexviewer (on my server)  there is a prompt for certificate, however, the flexviewer doesn't prompt for a certificate on loading the secure wms. Is there a way to force trigger prompt for certificate when reading in the secure wms?
DasaPaddock
Does it prompt for the client certificate in browsers other than IE?
At the bottom of this page is a workaround for IE that you could try adapting for your WMS server:
http://resources.arcgis.com/en/help/flex-api/concepts/index.html#/Secured_services/017p0000000900000...
