SearchWidget
2258
8
04-24-2013 05:04 AM
lifeEsri
I have this error when executing my searchWidget
[ATTACH=CONFIG]23736[/ATTACH]
RhettZufelt
MVP Notable Contributor
<?xml version="1.0" ?>
<configuration label="Louisville Parcels and Police">
<layers>
<layer>
<name>accidents</name>
<url>http://localhost:6080/arcgis/rest/services/SIGMALOGITEC/servicetest/MapServer/0</url>
<expression>accident = [value]</expression>
<textsearchlabel>Search by Parcel ID [ Example: 181001490000 or 1810%]</textsearchlabel>
<titlefield>accident</titlefield>
<linkfield></linkfield>
<fields all="false">
<field name="accident" alias="accident"/>
</fields>
</layer>
<layer>
<name>arrandissement</name>
<url>http://localhost:6080/arcgis/rest/services/SIGMALOGITEC/servicetest/MapServer/1</url>
<expression>objectid = [value]</expression>
<titlefield>objectid</titlefield>
<field name="objectid"/>
</fields>
</layer>
</layers>
<zoomscale>10000</zoomscale>
</configuration>
You are searching a number field, so as Robert pointed out, you need to remove the quotes. Also, LIKE looks for some matching operator (normally % depending on data source) and does not appear to work with number fields (at least not in ArcMap). You can query for a range of numbers, but not LIKE with wildcards.
R_
RobertScheitlin__GISP
life Esri,
   You need to verify your field names and the SQL of your where clause.
lifeEsri
life Esri,
I think all is ok but no result
this my filds of first layer(accidents):
[ATTACH=CONFIG]23737[/ATTACH]
and this my searchWidget.xml
<layers>
<layer>
<expression>accident like '[value]'</expression>
</fields>
</layer>
<layer>
<expression>objectid like '[value]'</expression>
</fields>
</layer>
</layers>
</configuration>
See Search widget tag reference at
http://links.esri.com/searchwidget
lifeEsri
NB: when i use arcGis Server 10 all is ok but when i try to use ArcGis Server 10.1 i have this problem
some help please
and thank in advance
lifeEsri
some one is here!!
I have a time constraint i need your help please
Your accidents field is numerical so your SQL should not have single quotes. This is all basic GIS stuff.
lifeEsri
Robert thank you for you help
but no result
I think i must to check something in the publication of my service in arcgisserver (Query is already checked)
in arcgisServer 10 it work's correctly but in 10.1 no results
RhettZufelt
<layers>
<layer>
</fields>
</layer>
<layer>
</fields>
</layer>
</layers>
</configuration>
R_
lifeEsri
thank you robert and zufelt for your helps
it's solved
