Search Widget
885
03-16-2013 05:17 PM
ArowanaIndah
I've field that relate to each other. My question
1. How to make when user pick value in Main Code, the value in Type Code only display a value that relate to Main Code and
value in Sub Code only display a value that relate to Type Code? i'm using expression below but it all show all the value
<expression alias="Status Code" textsearchlabel="Search Code:" isvaluerequired="False">
<values>
  <value prompt="Main Code" isvaluerequired="true" uniquevalsfromfield="Main_Code" >Main_Code = '[value]'</value>
  <value prompt="Type Code" isvaluerequired="true" uniquevalsfromfield="Type_Code" operation="AND" >Type_Code = '[value]'</value>
  <value prompt="Sub Code" isvaluerequired="true" uniquevalsfromfield="Sub_Code" operation="AND" >Sub_Code = '[value]'</value>
</values>
</expression>
2. How to make widget start searching when all value has been choose? I'm using expression above the widget start searching when i pick a first value.
Any help would be greatly appreciated.
Thank.
RobertScheitlin__GISP
Arowana,
  1. No currently there is no way to limit one dropdown based on the selection of another.
  2. Juts add the autosubmit="false" to each expression.
Arowana,
