Search Widget like statement
995
04-21-2011 09:27 AM
PaulMcBride
I'm trying to get a like statement to work for the searchWidget in the flexviewer 2.3.
First this is the code that works...
<?xml version="1.0" ?>
<configuration>
    <layers>
        <layer>
            <name>Madison County Parcels</name>
            <url>http://arcgis01.madisoncty.com/ArcGIS/rest/services/parcels/MapServer/25</url>
            <expression>KEYNO = '[value]'</expression>
            <textsearchlabel>Search by Parcel ID  [ Example: 00-0000-0-000, Smith]</textsearchlabel>
            <titlefield>Owner</titlefield>
            <linkfield></linkfield>
            <fields all="false">
             <field name="Owner"/>
             <field name="State_PIN"/>
             <field name="KEYNO"/>
            </fields>
        </layer>
    </layers>
    <zoomscale>7200</zoomscale>
</configuration>
    See Search widget documentation at
    http://links.esri.com/searchwidget
Now when I add the like statement I get no returns...
<configuration>
    <layers>
        <layer>
            <expression>KEYNO like '[%value%]'</expression>
            </fields>
        </layer>
    </layers>
</configuration>
Any help at all would be great cause I want to add the State_PIN and Owner fields to the expression but need to get at least one of them to work with the like statement.
JustinRiggs
This one works for me... maybe comparing it to yours will help...
Upper(name) LIKE Upper('%[value]%')
PaulMcBride
Thanks, that worked for that expression!
