Search Widget Expressions
1998
03-18-2014 07:50 AM
WalterDziuba
Is there a definitive reference manual that describes how to use the expression builder when you're trying to use
the search widget?
As an example, I'm trying to get this to run, but I keep getting a yellow triangle with an exclamation point indicating something is wrong with my expression.
BUILDINGTYPE like '[Apartment]'
Walter
RobertScheitlin__GISP
Walter,
your expression should look like this:
BUILDINGTYPE like '[value]%'
The widget will always replace the [value] with what the user types in the input box.
When using a like expression you normally will want to specify a wild character such as the % symbol.
As far as a manual you knowing what to type... No there is not one. It is just basic SQL query syntax.
From the documentation:
Tip:'[value]'  is a literal value that needs to be specified in the expression. The  apostrophe's are needed if working with string values.
Walter,
WalterDziuba
Robert,
That's great thanks. But if you wanted to preset the value:
So rather than have a value that the client has to input, then could I not use this to find bulding types that have attribute values of "Appartment"
BUILDINGTYPE like '[Apartment]%'
Walter
Walter,
  Sure just do not use the square brackets: App builder will continue to give you a warning (I think) but you can just ignore it.
BUILDINGTYPE like 'Apartment%'
WalterDziuba
Robert,
Didn't realize that my BUILDINGTYPE was a domain with only coded values. So to use the word "Apartment" made no sense to Flex. But when I changed the value to "2" which equals Apartments, it worked like a charm.
Thanks again.....Walter
