Run a widget after page load
1099
06-03-2012 05:58 PM
FarhadNavaei
I need to run a widget right after a page is completely loaded. Is there any way to do that?
Thanks
AnthonyGiles
Honored Contributor
Fnavaei,
If you are using the viewer and you want a widget to run/open automatically use the tag preload="open" in the main config file when you set the widget tag
Regards
Anthony
AnthonyGiles
Honored Contributor
Fnavaei,
Regards
Anthony
FarhadNavaei
Would you please explain it in a little details? I used the following code in widgetConfigLoaded event. It seems OK, but I'm not sure if it is right thing to do.
ViewerContainer.dispatchEvent(new AppEvent(AppEvent.WIDGET_RUN, 0));
Thanks
IvanBespalov
Farhad,
in FlexViewer versions 2.1, 2.2, 2.3:
ViewerContainer.dispatchEvent(new AppEvent(AppEvent.WIDGET_RUN, id));
in FlexViewer versions 2.4, 2.5, 3.0:
AppEvent.dispatch(AppEvent.WIDGET_RUN, id);
