rscheitlin's identify widget
3042
13
01-19-2012 06:40 AM
BenDrury
I am very new to Flex.  Just downloaded it last week.  I found all of Robert's AWESOME widgets and so far the one's I have worked with have been smooth sailing.  But the Identify widget has stumped me.  I configured the XML using the .pdf and readme text file supplied in the widget's download.  However, when I click on the Identify button in the map I get WidgetManager Error#2036...???  I've refreshed the cache in the browser and the rest API...  I know it's user error, but I have not been able to figure out what I've done wrong.  PLEASE help!
RobertScheitlin__GISP
Katrerine,
  I am glad you attached your code for the main config.
Here is your error:
<widget label="Identify" left="330" top="80"      icon="assets/images/i_info.png"      config="widgets/Identify/IdentifyWidget_Cookeville.xml"      url="widgets/Identify/IdentifyWidgets.swf"/>
Katherine,
   Sounds like you might have a syntax error in your IdentifyWidget.xml, please post your IdentifyWidget.xml
BenDrury
sorry.  I thought I did attach it...my bad....
won't let me attach the xml, so I saved it as a .txt file...
Katherine,
   The first thing I see is a syntax error in your commenting:
This is what you had:
<!--<useproxy>
        <proxylayer>
            <!-- <name>Imagery</name>
        </proxylayer>
    </useproxy>-->
this is corect:
<useproxy>
        <proxylayer>
            <!-- <name>Imagery</name> -->
        </proxylayer>
    </useproxy>
Don't forget to click the top arrow (promote) and to click the Mark as answer check as shown below:
BenDrury
Thank You.  I corrected that part, refreshed my browser cache & browser, but am still getting the WidgetManager Error#2036
Katherine,Are you using the compiled widget or using flash builder?
BenDrury
I am using the compiled_FV2.5
Katherine,   So do you actually get the widget to display and when you try to do an identify you get the error?If you don't even get the widget to display then please post your main config.xml
BenDrury
The widget does display.  It's when I click on the Identify Icon that I get the error...  If I close the error window and click the identify icon again the WidgetManager window opens, but just sits and spins...it doesn't do anything...  I refresh my browser cache and browser and again the same thing...
here is my config code anyway....
Katrerine,
Here is your error:
