Route Widget 3.0 Error
4340
12
02-12-2014 09:19 AM
AimeiChen
I noticed that ESRI's geocoding service and routing service already retired, so I changed the route service and geocode serivce as below in the routewidget.xml
<routetasksolver>http://route.arcgis.com/arcgis/rest/services/World/Route/NAServer/Route_World</routetasksolver>
<reversegeocode>http://geocode.arcgis.com/arcgis/rest/services/World/GeocodeServer</reversegeocode>
<singlelinegeocode>http://geocode.arcgis.com/arcgis/rest/services/World/GeocodeServer</singlelinegeocode>
but i kept getting error message "Unable to complete operation...clear and start again or add another valid stop." after typing in my AGOL login info.
Anybody here has same problem? Help, please!
Amy
AimeiChen
Amy,
   It might be possible but I can not say. I have never tried to downgrade a widget. Why are you still on a version of the viewer that is six minor releases behind?
Hi, Robert
Just to let you know that I downloaded your Route Widget 3.2 and load it into my 3.0 project, after fixing couple errors, it works perfectly now. Thank you so much for your contribution!!
Amy
RobertScheitlin__GISP
Amy,
   I just tested again and it works fine for me once I enter my credentials... What are the addresses you are attempting to route to and from?
AimeiChen
Amy,
Thanks Robert for your quick reply. I just noticed in the Address text box, the geocoded address missing state and zipcode. So it's like "1532 Pullan Ave Cincinnati,". Do I need to have my own Geocode service?
Amy
Amy,
   So it sounds like you are using the map click button to reverse geocode. Do you have the reversegeocode set in the xml?
AimeiChen
Amy,
yes, i do have it in the xml
Amy,
   What part of the world are you in? I am not sure why the reverse geocode is not returning state and zip if you are in the US.
AimeiChen
Amy,
Cincinnati Ohio 🙂
Amy,
   I am not sure what trouble you are having but when I click on the map in the same location I have no issue.
[ATTACH=CONFIG]31378[/ATTACH]
AimeiChen
Amy,
Thanks Robert. i noticed that your widget version is 3.6, are there any difference between version 3.0 and 3.6?
Amy,
   Sure it was not until 3.1.1 that I made the widget compatable with the new route service.
