Roll up Edit Widget combo box?
570
05-18-2012 01:00 PM
StephenLuzny
A combo box in the Edit Widget will not roll up without making a selection, unlike in the Search Widget. Is there any way to make the Edit Widget combo boxes behave like those in the Search Widget?
I found the following post and figure that the two widgets may use different classes for the combo box:
"the component used for the domain dropdown lists is not the DropDownListField as you would expect, but is actually the undocumented CodedValueDomainField"
(com.esri.ags.components.supportClasses.CodedValueDomainField)
http://forums.arcgis.com/threads/21608-Default-Attribute-Inspector-Dropdownlists-too-narrow..-how-to...
For reference:
Edit Widget sample: http://help.arcgis.com/en/webapps/flexviewer/live/index.html?config=apps/config-edit.xml
Search Widget sample: http://help.arcgis.com/en/webapps/flexviewer/live/index.html?config=apps/config-search.xml
