Roberts Identify Widget Issue with a Particular feature
10967
32
01-10-2012 02:30 AM
AlanHope
Hi Robert
You had been assisting me with an Issue regarding the identify widget in a separate thread located here.
I wanted to start a new thread so that you could get credit for answering a question should you be able to do that for me (I have no doubts that you will be able to help)
The previous thread is located In this link
I have now narrowed this down to an Issue with the particular feature
I added our Manholes to the XML and these were identifiable using the following XML
<?xml version="1.0" ?> <configuration>  <betareturngeometryfix>false</betareturngeometryfix>  <identifylayeroption>visible</identifylayeroption>  <identifytolerance>5</identifytolerance>  <defaultzoomscale>2000</defaultzoomscale>  <keepidentifyactive>true</keepidentifyactive>  <returngeometryforzoom>false</returngeometryforzoom>  <enablelineselect>true</enablelineselect>  <enbleextentselect>true</enbleextentselect>  <enablepolyselect>true</enablepolyselect>  <enablemouseovergraphicsinfo>false</enablemouseovergraphicsinfo>  <enablemouseoverrecordinfo>false</enablemouseoverrecordinfo>  <usemaptime>false</usemaptime>  <autoactivatedtool>point</autoactivatedtool><!-- possible values are extent or polygon or mappoint or polyline or nothing -->  <labels>   <zoom2message>Click to Zoom to Point</zoom2message>   <identifylabel>Identify</identifylabel>   <resultslabel>Results</resultslabel>   <descriptionlabel>Use the identify tool to identify features on the map:</descriptionlabel>   <pointlabel>Identify by Point</pointlabel>   <linelabel>Identify by Polyline</linelabel>   <rectlabel>Identify by Rectangle</rectlabel>   <polylabel>Identify by Polygon</polylabel>   <clearlabel>Clear</clearlabel>   <loadinglabel>Loading...</loadinglabel>  </labels>  <useproxy>   <proxylayer>    <!--name>Imagery</name-->   </proxylayer>  </useproxy>  <layers onlythese="true">   <layer>    <name>Manholes</name>    <fields>UGS_ID,NEIGHBORHO</fields>    <links>     <link includeinresults="false" field="" alias="">      <linkprefix></linkprefix>      <linksuffix></linksuffix>      <iconfield></iconfield>      <iconprefix></iconprefix>      <iconsuffix></iconsuffix>     </link>    </links>    <zoomscale>2000</zoomscale>    <forcescale>false</forcescale>   </layer>     <layer>    <name>Pole Master</name>    <fields>POLEID,MUNI</fields>    <links>     <link includeinresults="false" field="" alias="">      <linkprefix></linkprefix>      <linksuffix></linksuffix>      <iconfield></iconfield>      <iconprefix></iconprefix>      <iconsuffix></iconsuffix>     </link>    </links>    <zoomscale>2000</zoomscale>    <forcescale>false</forcescale>   </layer>  </layers>  <symbols>      <simplefillsymbol color="0x448ccb" alpha="0.4" style="solid">       <outline color="0x448ccb" alpha="0.8" width="2"/>      </simplefillsymbol>      <simplemarkersymbol style="circle" size="12" color="0x448ccb" alpha="0.8" xoffset="0" yoffset="0" angle="0">       <outline style="solid" color="0xffffff" alpha="0.8" width="1"/>      </simplemarkersymbol>      <picturemarkersymbol url="assets/images/i_info.png" height="30" width="30" xoffset="0" yoffset="0" />   <simplelinesymbol color="0x448ccb" alpha="0.8" width="2"/>     </symbols> </configuration>
However the Pole Master features are not returned in the identify results
Here is my REST end point
Layer: Pole Master (ID: 0)
Display Field: POLEID
Type: Feature Layer
Geometry Type: esriGeometryPoint
Fields:
OBJECTID (Type: esriFieldTypeOID, Alias: OBJECTID)
POLEID (Type: esriFieldTypeString, Alias: POLEID, Length: 16 )
MUNI (Type: esriFieldTypeString, Alias: MUNI, Length: 20 )
The Pole Master Table is a bit of beast and we are in the process of restructuring it however this wont be for the next 6-12 months.
Any ideas why the Manholes show but the Poles do not?
I will post the IE Dev mode response in the next post as it took me over the limit
Thanks for any assistance you are able to provide
Al
RobertScheitlin__GISP
Alan,
  Well here is the bad news and good news... The Good is that I was successfully able to identify the mapservice I produced using they FGDB you provided. That means the bad news is that you have a configuration or an actual map service corruption issue. Next recommended step would be to has your GIS Manager export out the whole layer and publish a new seperate map service for this layer and test it with the identify widget.
[ATTACH=CONFIG]11082[/ATTACH]
AlanHope
IE Dev mode response body
{"results":[{"layerId":0,"layerName":"Pole Master ","value":"719-767","displayFieldName":"POLEID","attributes":{"OBJECTID":"305786","POLEID":"719-767","MUNI":"PITTSBURGH","BELLID":"","TYPE":"Steel","HEIGHT":"","CLASS":"","OWNERSHIP":"CITY","NOTES":"","TIME":"","DATE_":"2/11/2002","OTHERID2":"","EMPLOYEE_":"9911","DLC_DIST":"1","DLC_COM":"0","DQE_COM":"0","STLITE":"1","BELL1":"0","ALLTEL1":"0","NPT1":"0","ARMSTRNG1":"0","FIBOPT":"0","OTHER":"0","OTHER2":"0","FIBOPT2":"0","FIBOPT3":"0","CABLE_AREA":"WAR-1","PHONE_PWR":"0","CABLE_PWR":"0","CABLE_FO":"0","CABLE_FO2":"0","TAGGED":"0","MAPPED":"0","REPLACE":"0","CABLE_NO":"0","PHONE_NO":"0","WMIS_1":"0","WMIS_2":"0","WMIS_3":"0","REVDATE_1":"Null","REVDATE_2":"Null","REV_DATE_3":"Null","PTE":"0","NO_ANCHORS":"0","SWITCH":"","SECTIONAL":"","SCADAMATE":"","VIPER":"","RECLOSER":"","CAPACITOR":"","STREET":"","URD_KEY":"","URD_PLAN":"","URD_PATH":"","CIRCUIT":"","X_COORD":"1344907.69865","Y_COORD":"411188.07604","MAP":"","CHDATE":"Null","EMPL":"","EMP2":"","STNO":"","STSEG":"","LEAN":"0","BDTP":"0","BDAR":"0","ANCH":"0","UGCB":"0","REIF":"0","NLHGT":"0","NLDATE":"","VECH":"0","SPLY":"","QLTY":"","PLANT":"","MNTH":"","PLNTYR":"0","SPCS":"","CHEM":"","BRHGT":"0","MEAS":"","FIBRD":"0","UTT":"0","REPLACEREQ":"0","SETIN":"","DRILLED":"0","DIAM":"0","NOTEST":"0","UNIQ_ID":"1344908411188","GIS_SHEET":"5139","CAB_AGREE":"","PROP_CO":"","AGREEMENT":"","LOCKDATE":"Null","LDATE15":"Null","LDATE60":"Null","COMPANY1":"","CO1_AGREE":"","CO1_DATE":"Null","COMPANY2":"","CO2_AGREE":"","CO2_DATE":"Null","COMPANY3":"","CO3_AGREE":"","CO3_DATE":"Null","CO1_NOTES":"","CO2_NOTES":"","CO3_NOTES":"","SERVCNTR":"PREB","Shape":"Point","PIC1":"\\\\s0052\\gisbig\\download\\9911\\pic24\\mvc-873s.jpg","PIC2":"\\\\s0052\\gisbig\\download\\9911\\pic24\\mvc-s.jpg","PIC3":"Null","PIC4":"p:\\download\\9911\\pic24\\mvc-s.jpg","CURATTNOTES":"Null","CIRCUIT2":"Null","CIRCUIT3":"Null","CIRCUIT4":"Null","CIRCUIT5":"Null","URD_YEAR":"Null","URD_SUBM":"Null","URD_COMRES":"Null","URD_PAD":"Null"}},{"layerId":1,"layerName":"Manholes","value":"7846","displayFieldName":"UGS_ID","attributes":{"OBJECTID_1":"1180","OBJECTID":"1960","UGS_ID":"7846","MAPKEY":"","NAME":"","CKT_NO":"0","SPOT":"","VOLTAGE":"","ZONE_":"0","SUBTYPE":"OCT2W","SYMBOL":"164","ROTATION":"0.2046","UGS_LENGTH":"97","UGS_WIDTH":"62","UGS_HEIGHT":"0","DIG_DEPTH":"159","DRAWING_NB":"W-122","UGS_TYPE_C":"MAN2WY","LID":"2-6","X_COORD":"1344950.7922","Y_COORD":"411214.39908","STREET":"CENTER","MUNI":"PITTSBURGH","DATE_":"Null","EMPLOYEE":"2382","LENGTH":"8-1","WIDTH":"5-2","DEPTH":"13-3","NEIGHBORHO":"CENTRAL BUISNESS DISTRICT","X_COORD_1":"1344950.7922","Y_COORD_1":"411214.39908","UNIQ_ID":"1344951411214","Shape":"Point"}},{"layerId":3,"layerName":"Duct Lines - Downtown","value":"129594","displayFieldName":"TAG","attributes":{"OBJECTID":"540","FNODE_":"0","TNODE_":"0","LPOLY_":"0","RPOLY_":"0","LENGTH":"314.8268","DU_ELEC_L1":"0","DU_ELEC_L2":"0","TAG":"129594","TYPE":"ULS","SUBTYPE":"DCTBNK","SYMBOL":"135","ZOOM_SYMBO":"135","FJUNCTION":"21707","TJUNCTION":"21710","LOCK__ID":"0","PHASE__ID":"0","Shape":"Polyline","SHAPE.LEN":"314.826804"}},{"layerId":3,"layerName":"Duct Lines - Downtown","value":"129595","displayFieldName":"TAG","attributes":{"OBJECTID":"535","FNODE_":"0","TNODE_":"0","LPOLY_":"0","RPOLY_":"0","LENGTH":"235.6998","DU_ELEC_L1":"0","DU_ELEC_L2":"0","TAG":"129595","TYPE":"ULS","SUBTYPE":"DCTBNK","SYMBOL":"135","ZOOM_SYMBO":"135","FJUNCTION":"21710","TJUNCTION":"21711","LOCK__ID":"0","PHASE__ID":"0","Shape":"Polyline","SHAPE.LEN":"235.699893"}},{"layerId":12,"layerName":"Allegheny Parcels","value":"2-G-321","displayFieldName":"MAPBLOCKLO","attributes":{"OBJECTID":"214330","PIN":"0002G00321000000","MAPBLOCKLO":"2-G-321","MUNICODE":"103","PROPERTYOW":"SPORTS & EXHIBITION AUTH OF PITTSBURGH &ALLEGHENY COUNTY","PROPERTYAD":"","PROPERTYHO":"50","PROPERTY_1":"CONGRESS ST","PROPERTYUN":"","PROPERTYLO":"","PROPERTYCI":"PITTSBURGH, PA","PROPERTYZI":"15219","MUNDESC":"PITTSBURGH - 3RD WARD","OWNERDESC":"Corporation","STATEDESC":"Other","USEDESC":"CHARITABLE EXEMPTION/HOS/HOMES","CHANGENOTI":"REGIONAL ENTERPRISE TOWER","CHANGENO_1":"425   6TH AVE  STE 2750","CHANGENO_2":"PITTSBURGH, PA 15219-","CHANGENO_3":"","AGENTNAME":"SPORTS & EXHIBITION AUTHORITY OF        PITTSBURGH & ALLEGHENY COUNTY","TAXBILLFUL":"REGIONAL ENTERPRISE TOWER","TAXBILLF_1":"425   SIXTH AVE SUITE 2750","TAXBILLF_2":"PITTSBURGH, PA 15219-","TAXBILLF_3":"","Shape":"Polygon","SHAPE.AREA":"29110.049251","SHAPE.LEN":"991.957481"}},{"layerId":12,"layerName":"Allegheny Parcels","value":"2-G-306","displayFieldName":"MAPBLOCKLO","attributes":{"OBJECTID":"214129","PIN":"0002G00306000000","MAPBLOCKLO":"2-G-306","MUNICODE":"103","PROPERTYOW":"EPIPHANY ROMAN CATHOLIC CHURCH ETAL","PROPERTYAD":"","PROPERTYHO":"1018","PROPERTY_1":"CENTRE AVE","PROPERTYUN":"","PROPERTYLO":"","PROPERTYCI":"PITTSBURGH, PA","PROPERTYZI":"15219","MUNDESC":"PITTSBURGH - 3RD WARD","OWNERDESC":"Corporation","STATEDESC":"Other","USEDESC":"CHURCHES, PUBLIC WORSHIP","CHANGENOTI":"","CHANGENO_1":"1018   CENTRE AVE","CHANGENO_2":"PGH, PA 15219-","CHANGENO_3":"","AGENTNAME":"","TAXBILLFUL":"","TAXBILLF_1":"1018   CENTRE AVE","TAXBILLF_2":"PITTSBURGH, PA 15219-","TAXBILLF_3":"","Shape":"Polygon","SHAPE.AREA":"45994.08213","SHAPE.LEN":"858.792714"}},{"layerId":23,"layerName":"Allegheny Streets with Penn DOT Accident Zones","value":"Centre","displayFieldName":"ST_NAME","attributes":{"OBJECTID":"81763","LENGTH":"625.6113","PREFIX":"","TYPE":"Ave","SUFFIX":"","STNME":"Centre Ave","ST_NAME":"Centre","MUNI":"Pittsburgh","ALTERNATEN":"","LLEFT":"0","HLEFT":"0","LRGT":"0","HRGT":"0","FROMSTREET":"Washington Pl","TOSTREET":"Mario Lemiux Pl","ZIPL":"15219","ZIPR":"15219","MCDL":"100","MCDR":"100","OWNER":"City","BELTWAY":"","MAJORRD":"Yes","NO_LANES":"3","CFCC":"A31","GDTLINK":"","ONEWAY":"n","STCL_CODE":"0","UNIQUE_ID":"12799","ROUTE_NO":"","DO":"y","RECNO":"18247","CKT_NO":"","GEO_CD":"719","HAZARD":"Null","SEGMENT":"Null","PENNDOT":"Null","Shape":"Polyline","SHAPE.LEN":"625.611302"}},{"layerId":43,"layerName":"Edge of Roads","value":"12194","displayFieldName":"OBJECTID","attributes":{"OBJECTID_1":"90871","OBJECTID":"12194","FNODE_":"9606","TNODE_":"9750","LPOLY_":"0","RPOLY_":"0","LENGTH":"792.77582","PGMAJT_":"12194","PGMAJT_ID":"30184","MAJTRANS_C":"1010","Shape":"Polyline","SHAPE.LEN":"792.775837"}},{"layerId":43,"layerName":"Edge of Roads","value":"12188","displayFieldName":"OBJECTID","attributes":{"OBJECTID_1":"57437","OBJECTID":"12188","FNODE_":"9606","TNODE_":"9750","LPOLY_":"0","RPOLY_":"0","LENGTH":"362.98845","PGMAJT_":"12188","PGMAJT_ID":"30183","MAJTRANS_C":"1090","Shape":"Polyline","SHAPE.LEN":"362.988531"}},{"layerId":43,"layerName":"Edge of Roads","value":"12189","displayFieldName":"OBJECTID","attributes":{"OBJECTID_1":"91738","OBJECTID":"12189","FNODE_":"9751","TNODE_":"9607","LPOLY_":"0","RPOLY_":"0","LENGTH":"343.77684","PGMAJT_":"12189","PGMAJT_ID":"30138","MAJTRANS_C":"1090","Shape":"Polyline","SHAPE.LEN":"343.776901"}},{"layerId":43,"layerName":"Edge of Roads","value":"11910","displayFieldName":"OBJECTID","attributes":{"OBJECTID_1":"95838","OBJECTID":"11910","FNODE_":"9236","TNODE_":"9236","LPOLY_":"0","RPOLY_":"0","LENGTH":"2539.19253","PGMAJT_":"11910","PGMAJT_ID":"30188","MAJTRANS_C":"1010","Shape":"Polyline","SHAPE.LEN":"2539.192353"}}]}
Alan,
   Does this point feature z aware?
AlanHope
Alan,
Robert
I am farily new to GIS so please forgive my ignorance but how would I verify that the point is Z aware?
Thanks
Al
Alan,
   In ArcCatalog find the feature Pole Master and right click on it and choose properties and under the general tab see if the "Coordinates include Z values. Used to store 3D data." has a check next to it.
AlanHope
Alan,
This option is unchecked
I also verified and the manholes are configured the same way (Manholes are functional)
Alan,
   Have you tried to only having the Pole Master layer listed in the IdentifyWidget.xml?
AlanHope
Alan,
Robert
I tried the following after clearing the REST cache and the browser cache - and got nothing presented in the widget after drawing a rectangle around 2 points, I also attempted with the point selector and got nothing in the results.
  <!-- <layer>
   <links>
    </link>
   </links>
  </layer> -->
    <layer>
   <fields>POLEID,OWNERSHIP,MUNI</fields>
   <links>
    </link>
   </links>
  </layer>
 </layers>
I uncomment the Manholes section and get manholes results? I'm confused (although this is a normal state of affairs!!) 🙂
Alan,
   Try leaving the manholes commented out but change the onlythese to false and see what happens.
AlanHope
Alan,
Tried this
 <layers onlythese="false">
<!--<layer>
   <links>
    </link>
   </links>
  </layer> -->
    <layer>
   <links>
    </link>
   </links>
  </layer>
 </layers>
and here is what I got
[ATTACH=CONFIG]11041[/ATTACH]
Which makes me think that may XML is not getting parsed correctly??
