Robert's Splash Widget - setTimeout - Load Delay
2641
01-06-2012 04:46 AM
philippschnetzer
I have several things going on when my app first loads and if the user clicks the Agree button on the splash widget as quickly as possible the rest of things that are loading sometimes get messed up/repositioned...
So, I would like to put a short load delay on the splash widget to give everything enough time to load before the user enters the site....
Ive tried to include this:
setTimeout(init, 4000);
at the end of the init function but the initial splash page still loads and then an additional splash page loads every 4 seconds...
Thanks for helping!!
RobertScheitlin__GISP
Phillip,
  Will this work for you?:
Code for the SplashTitleWindow
protected function addButtons():void             {                 for (var i:int = 0; i < _buttons.length(); i++)                 {                     var btnURL:String = _buttons.@url;                     var btnLabel:String = _buttons.@label;                     var btnAction:String = _buttons.@action;                     var btn:Button = new Button();                     btn.label = btnLabel;                     btn.name = btnURL;                     switch (btnAction)                     {                         case "close":                         {                             btn.addEventListener(MouseEvent.CLICK, btnClose);                             btn.enabled = false;                             setTimeout(enableAgree, 4000);                             function enableAgree():void{                                 Button(bGroup.getElementAt(0)).enabled = true;                             }                             break;                         }                         case "redirect":                         {                             btn.addEventListener(MouseEvent.CLICK, btnRedirect);                             break;                         }                         case "link":                         {                             btn.addEventListener(MouseEvent.CLICK, btnLink);                             break;                         }                     }                     bGroup.addElement(btn);                 }             }
Phillip,
philippschnetzer
Perfect, thanks Robert!!
Phillip,
   I am not sure what it looks like yet but there is suppose to be an answered button now that you push to give me points for answering your post.
Hmm... There is definitely going to be a learning curve here... You marked your own response as the answer.
