Robert's Identify Tool 2.4
1869
08-25-2011 01:14 PM
BenFerguson
Robert,
I think I identified (no pun intended) a bug in you tool.  If you don't have <returngeometryforzoom> set to true (or have it missing), then code later one throws an error as it is expecting geometry  (line 751 and 811, depending on the configuration.
Anyways, thanks for all the good work!
Ben
RobertScheitlin__GISP
Ben,
   Hmm... Thanks for finding that bug it has been around for several versions after looking at the code. Strange no one found it till now. I have it fixed but am not 100% happy with the solution but it may have to do. Developer are always picky when it comes to their code. I will release a new version with the fix soon.
bflodine
Hello Robert,
Your new widget works very well.....Is it possible to change the colors of the field names to make them different from the field attributes?
Brett
Brett,
  Currently not possible but I will look into this for the next release.
LemvigKommune
Hi Robert
First, great widget, but when I use it, and move the mouse over the resultlist, it takes abouth 15-17 seconde to show the popup-info.
It is almost like the browser crashes.
Sorry - found the error - i had my autoCompleteSearch widget open that used a geometry-service - that desturbed your widget
Mads
