Robert's Enhanced Search Widget - Datagrid button
3434
01-11-2012 05:09 AM
AshleyPeters
How do I remove the Datagrid button from the widget? None of the layers I use require that the results be opened in a grid. I figure this is an easy fix and that I'm just missing where I change the code.
Thanks in advance for the help!
RobertScheitlin__GISP
Ashley,
   Sorry that was my mistake, that only disables the blue results button. The latest Version 2.5.1.1 available now does have the disablebuttons option for datagrid.
http://www.arcgis.com/home/item.html?id=5d4995ccdb99429185dfd8d8fb2a513e
Ashley,
   It doesn't require a code change. All you have to do is disable the button in the SearchWidget.xml
<disablebuttons>grid</disablebuttons><!--possible values one or more not all three search types comma separated text,graphic,spatial,grid -->
This is explained in the Enhanced Search Widget XML Configuration.pdf
AshleyPeters
I completely missed that. Thanks Robert!
AshleyPeters
When I tried that, it removed the results button. The green table button is still there. See the attached screenshot with message stating 'datagrid not configured'.
Ashley,
AshleyPeters
That got it. Thanks Robert!
