Remove Powered by ESRI in FlexViewer 2.1
6757
23
10-19-2010 05:30 AM
EricVenden
I am pretty new to the Flex Viewer arena.  I am trying to find where the reference to the "Powered by ESRI" logo (lower right corner of the map window) is located.  I have found references in other older threads to the MapManager.mxml, but I cannot find this on the server (wondering if this is a version difference???)
Any help would be appreciated
Thanks
Eric Venden
Gurnee, IL
DasaPaddock
The logo comes from the ArcGIS API for Flex. You can hide it by setting adding this to the MapManager's partAdded() function:
map.logoVisible = false;
JoshuaCoates
If you hide it, and replace with your own logo...How do you make it not open the ESRI website when I click my own logo? I am able to get my website to open, the ESRI site just opens simultaneously with it?!
philippschnetzer
i just removed the logo as has been suggested previously...then used the staticImage widget to place my logo. Then insert the 'click="xxxxxxxxxxx..." code shown below at the end of the staticImage.mxml and it makes your logo clickable with a link to a url.
 if (dataTable.key == IMAGE_URL)
                    img.source = dataTable.collection[0];
    </fx:Script>
    <mx:VBox width="100%" height="100%">
  <!-- PS - added click event for url link -->
        <mx:Image id="img" width="205" click="navigateToURL(new URLRequest('http://www.gissolutions.ca'), 'quote')"
      useHandCursor="true"/>
    </mx:VBox>
</viewer:BaseWidget>
JoshuaCoates
Thanks, I got it working perfectly! Is there anyway to make it where there is a hand instead of the regular mouse arrow so that Users know it is click able?
DasaPaddock
Try also setting the buttonMode to true on the Image.
JoshuaCoates
How do you do this? I do not see buttonMode??
JoshuaCoates
CynthiaMatney
Thanks - this was helpful.  However, I am wanting to get my city logo (static image) to be at the bottom right hand corner of my map - and I cannot get it to that location.
What do I need to do to change the location?
Thanks!
philippschnetzer
You can specify location in the config.xml.  Specifically, put the following line under
<!-- UI elements --> in your main config.xml...
<widget bottom="2" right="27"  config="widgets/StaticImage/StaticImageWidget.xml" url="widgets/StaticImage/StaticImageWidget.swf"/>
To change the size of the image you will need to change the 'width="xxx"' property found in a code block shown above in red...
